| Home > Technical Chat > Decompression plates | |||||||
11th Dec, 2004 at 09:53:34pm
Just found some at mike farriday engineering,also thick solid copper gaskets.
11th Dec, 2004 at 11:03:33pm
as a last resort...
AlexF |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
16th Dec, 2004 at 12:51:26am
I've been thinking about this also. A lot of people have been grinding on about the importance of "Squish". I'm not that convinced how important it is on a regular blown engine, running comfortably. Certainly, it allows you to get an edge but must entail some serious setting up.
Bugger off, I'm getting there. |
16th Dec, 2004 at 11:06:49pm
Rocker geometery is already lousy using aftermarket cams and roller rockers. Adding one of these plates makes it even worse...
17th Dec, 2004 at 10:29:12am
You won't be able to run near the point of det with large regions of "end gasses". They will just pop and destroy your ring lands.
AlexF |
17th Dec, 2004 at 09:51:19pm
Depends, I heard you could skim the rocker pillars down a bit. Not sure how much though.
18th Dec, 2004 at 11:38:48am
You need a gasket either side of the shim...
AlexF |
18th Dec, 2004 at 11:43:00am
So if you made the hole in the plate the same size as the dish in the piston it would be sorted
18th Dec, 2004 at 01:47:00pm
I believe so.
19th Dec, 2004 at 05:05:12am
All this talk about squish is all well and good, but I've no squish in my head at all - not exactly a slouch either...
Edited by turbodave16v on 19th Dec, 2004. On 17th Nov, 2014 Tom Fenton said:
19th Dec, 2004 at 01:06:04pm
There's always the lathe and some bits of (quality) steel.
155 Posts Member #: 246 Advanced Member Cumbria |
19th Dec, 2004 at 02:47:37pm
I thought MED sold adjustable pushrods ?
24th Dec, 2004 at 07:18:34pm
On 19/12/2004 13:06:04 Hedgemonkey said:
"Don't bother" I know exactly what you're struggling with - part of the reason why i decided not to pursue it a while back! It's only when you put it next to the 'A' you realise how damn big it is!!! Have you not thought about using an inlet manifold set-up like on the ford F150 lightning? This has a charge cooler build into the inlet. Not as good as a FMIC, but lots better than no intercooler... On 17th Nov, 2014 Tom Fenton said:
25th Dec, 2004 at 12:33:26pm
No, it's going there come hell or high water.
28th Dec, 2004 at 08:34:23pm
jsut a quickie, incase you havnt considered it. and i could be wrong as its beena good while since i last handled a bini blower, but what about mounting it into the inner wing area? it might be a bit long, but might not!
31st Dec, 2004 at 03:28:34pm
They are gigantic.
7th Oct, 2005 at 09:49:25pm
On 16/12/2004 23:06:49 TurboDave said:
Rocker geometery is already lousy using aftermarket cams and roller rockers. Adding one of these plates makes it even worse... Fine if you can source some pushrods around 1/4" longer than the A-series ones... If the block was decked and low hieght pistons used then this would improve the Rocker geometery
10th Oct, 2005 at 07:28:50am
It would definately reduce piston to bore friction, and that's a good thing. On 13th Jul, 2012 Ben H said:
