| Home > Help Needed / General Tech Chat > Removable steering wheel. | |||||||
784 Posts Member #: 912 Post Whore North Yorkshire |
6th Oct, 2009 at 12:49:10pm
Right I require some advice about the above please.
I drill holes in everything..! |
6th Oct, 2009 at 01:10:36pm
garry the oneeyedlizard has one on his car, have a look in his pics On 28th Aug, 2011 Kean said:
6th Oct, 2009 at 01:49:44pm
Merlin do a range:
6th Oct, 2009 at 09:00:29pm
I got mine from SPA, nice piece of kit. Isambard Kingdom Brunel said:
6th Oct, 2009 at 09:02:38pm
I use a Snapoff boss mounted to a machined down Mountney classic boss. This makes the complete boss about the same hight as a standard boss. I then use a deep dish steering wheel to shorten the reach.
Edited by Sprocket on 6th Oct, 2009. On 26th Oct, 2004 TurboDave16v said:
6th Oct, 2009 at 11:49:28pm
Mine's from eBay. Like this...
Edited by theoneeyedlizard on 6th Oct, 2009. In the 13's at last!.. Just |
7th Oct, 2009 at 10:12:14pm
So basically I need to get a boss and then you can fit whatever you like to it.?
8th Oct, 2009 at 12:44:41am
You are screwed if you have a Mountney classic steering wheel as none of the snap off bosses will fit. It needs to be the smaller 'sport' type boss that Sparco, Momo and the like use. On 26th Oct, 2004 TurboDave16v said:
8th Oct, 2009 at 10:19:04am
you need the smaller boss, the indicator cancel still works, you can then fit a snap off style of boss
8th Oct, 2009 at 10:23:37am
basically
Edited by wolfie on 8th Oct, 2009. Crystal Sound Audio said:
8th Oct, 2009 at 12:54:25pm
I use a hub from Minispares, and a removeable thingy from OMP. Works great, but you'll need to move the seat behind the cross member
11th Oct, 2009 at 07:43:20am
Cheers guys, Hopefully get something sorted this week.
203 Posts Member #: 1734 Senior Member Lancaster |
11th Oct, 2009 at 11:10:41am
I'm not into the ball lock system myself. (reminds me of the tractor hydraulics connector). I tried a couple of these and they both had a few mm of slop in them, which got progressively worse over time when the balls wore the interface holes out. I hope others have better luck than I did. |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
11th Oct, 2009 at 01:41:37pm
The thing to look out for is the slop in the splines. The splines in the Formula student car i work on is shocking. About 5-10 degrees of play is terrible. In boost we trust |
