| Home > General Chat > Opinions on these plugs | |||||||
8th Oct, 2009 at 09:42:13am
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=270464606063
8th Oct, 2009 at 09:56:19am
I wouls steer well clear. I had a set of super 4s (WR78, I think) in my standard 998 and they lasted about 3000km. They produced a weird problem of breaking down under load but only when all 4 were connected. I unplugged one to check mixture with colourtune as I thought my fuelling was out and the problem would disappear.
Gary's description is best |
8th Oct, 2009 at 10:04:40am
I can really recommend the NGK iridium plugs, used to use them in my nissan, so tried them in the mini, have been very good so far, much better than the standard jobs.
8th Oct, 2009 at 10:08:12am
Cheers guys! If something is worth doing, it's worth doing half of. |
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
8th Oct, 2009 at 02:44:45pm
I am using the BPR 8EIX plugs, the are great and have a recessed electrode, that minimizes the hot spot that a normal plug usually creates (which could cause detonation).
8th Oct, 2009 at 03:00:21pm
Im using std metro turbo plugs |
8th Oct, 2009 at 03:02:26pm
Your special though Nic!
On 8th Oct, 2009 Nic said:
Im using std metro turbo plugs If something is worth doing, it's worth doing half of. |
8th Oct, 2009 at 05:51:03pm
i was using NGK escort RS turbo plugs |
8th Oct, 2009 at 09:18:46pm
On 8th Oct, 2009 t2clubby said:
I can really recommend the NGK iridium plugs, used to use them in my nissan, so tried them in the mini, have been very good so far, much better than the standard jobs. BPR 6EIX BPR 7EIX Are what you need, depending on what grade you want. Not cheap mind. I use the same... wickedly thin electrode.. would hurt if you stabbed someone in the eye with it. I run a supercharger and I don't care the TB is on the wrong side.
8th Oct, 2009 at 10:13:19pm
I also use the NGK iridium plugs in my 205 turbo, and also the DON.
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
9th Oct, 2009 at 11:45:04pm
Not tried the iridium plugs but managed to gain 10 BHp on VMax's RR by changing from NGK BCR8ES to BCR7ES.
10th Oct, 2009 at 08:16:57am
I tried them about 10 years ago in my Metty Turbo, I can't remember what they were like but I didn't buy a second set. Isambard Kingdom Brunel said:
10th Oct, 2009 at 08:45:10am
I use the RS turbo spec NGKs BPR8ES iirc.
10th Oct, 2009 at 12:49:26pm
same as me wil,
10th Oct, 2009 at 04:05:40pm
I remember a good few years ago when the bosch supre 4s came out. There seemed to be a raft of fancy plugs on the market so a magazine (can't remember which one) got a bog standard Astra GTE and did a back to back power run with about 10 different plugs all claiming improved power, efficiency, life, etc. The outcome was that the standard plugs the car came with, NGK Rs, got the best power. Some matched the original power, most were worse and all were at least twice the price. http://www.twin-turbo.co.uk
