| Home > Help Needed / General Tech Chat > new 'pump like' sound comming from pressure regulator.. | |||||||
10th Oct, 2009 at 08:43:33am
Hi, fired up the car today and my fuel pressure regulator sounded odd.. a bit like a pump or a gulping sound, any ideas why this could be and how to remedy it?
10th Oct, 2009 at 10:28:52am
split fuelline? Drives
10th Oct, 2009 at 10:33:48am
On 10th Oct, 2009 Paul R said:
split fuelline? no signs of fuel pissing out.. |
10th Oct, 2009 at 11:36:17am
Mine does sometimes mate, never had a problem with it.
10th Oct, 2009 at 11:59:49am
It coud be the pressure line from the plenum is split. With the car at idle it will be in negative pressure so will be drawing air in and making a weird noise On 12th Nov, 2009 Paul S said:
Gary's description is best |
10th Oct, 2009 at 02:09:26pm
On 10th Oct, 2009 t2clubby said:
Mine does sometimes mate, never had a problem with it. Maybe just pushing air out o the system after sitting for a while thinking this could be it.. i had i sat for over 2 weeks took it for a run today and i seems ok again.. |
10th Oct, 2009 at 05:38:42pm
itll be air in the system :) makes a weerd sound a mix between gulping and chirping. turbo 16v k-series 11.9@118.9 :)
10th Oct, 2009 at 07:46:18pm
Air. The DON will do this if if gets low on fuel.
11th Oct, 2009 at 05:27:52pm
mine does it if i leave my pump running. I think its the diaphragm bouncing. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Oct, 2009 at 06:15:58pm
glad its nothing to worry about then. Cheers chaps. |
