| Home > Help Needed / General Tech Chat > what is the little plug on turbo feed bolt(engine side) for? | |||||||
83 Posts Member #: 6003 Advanced Member |
10th Oct, 2009 at 06:29:08pm
is it limit the oil flow?
10th Oct, 2009 at 07:13:57pm
That fits on the inlet manifold. It is a one way valve to stop the boost pressure in the manifold pressurising the breather system.
10th Oct, 2009 at 08:01:52pm
On 10th Oct, 2009 Tom Fenton said:
That fits on the inlet manifold. It is a one way valve to stop the boost pressure in the manifold pressurising the breather system. the other side connect to dump valve? is it necessary? |
11th Oct, 2009 at 10:25:57am
You cannot use it to trigger the dump valve as it is a one way valve. Just ditch it and use something else, or if you must use it, you can drill out the one way valve inside.
