Home > Technical Chat > Turbo Head Gasket
ERA ANT
Member #: 4179
Cumbria
does anyone on here run one of them steel cometic turbo head gaskets? i know that they are used on diesel engines and they run 400psi compression so must be good. just wondered if anyone runs one? if so are they any good?
Do it right the first time and make it mint!!!!!!
Mini13 uses one. It sounds like a good gasket.
Not sure he would have paid the £70 asking price if he could get hold of a Decent bk450.
Edited by theoneeyedlizard on 12th Oct, 2009.
yep I'm running one at the moment, as above I only went with it due to the iffy BK's,
TBH I don't think its worth the extra in most cases as the BK450 is up to the job,
Also i think really the head and block faces need to be really smooth for the cometic, ie surface ground rather than just skimmed.
Monkeh
Member #: 1997
Lichfield
i run one too, for piece of mind more than anything
its one of those things you fit and forget, but as mini13 said, both faces should be ground as smooth as they can get it.
BK450 job done torqued to 55 ft pounds
*happy*
im happy if you are steve
Mr Joshua
Member #: 1954
Luton Bedfordshire
I wonder how many get their torque wrenches checked or calibrated?
Own the day
true...FT normally works well.....
ERA ANT
Member #: 4179
Cumbria
cheers lads thats a great help. 8-)
turbominivanman
Member #: 1504
Westbury, Wiltshire
Believe Jani's using one in his SC Cabrio.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=316209
Richard.
Edited by turbominivanman on 14th Oct, 2009.
