Home > General Chat > is my mini heavy?
Carl
Member #: 95
liverpool-on-sea
just moted my mini and the new brake tester we have actually weighs the car as well.
its a clubby shell with fibreglass front, starlet turbo engine, homemade subframe full road trim.
so my mini weighed 815kgs
tools and water etc -13kgs
spare wheel - 6kgs
me -100kgs
so is this heavy compared to others?
It is heavy, but if its got the comfy interior etc then not too bad
Paul
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
696kg is quite heavy. I think mine was 630kg at the last test and I aven't got any light parts on it other than a rusted subframe and a cf front. What meterial is the starlet head and block?
On 30th Apr, 2010 Rod S said:
Gary's description is best
Carl
Member #: 95
liverpool-on-sea
its not really comfy lol i took all the sound proofing out. just need a mini with 3 seats.
my home made subby weighs about double a standard one weighs.
cylinder head is ally, the block is proper metal lol. cant find the combined weigh of engine and box anywhere.
dont know how acurate the machine is i assume its gotta be about right tho, it measures front axle then the rear.
Edited by Carl on 14th Oct, 2009.
take it to a weigh bridge at a scrapers and find out properly, just make sure they don't knick it for scrap *wink*
EDIT: I can't type or spell....
Edited by apbellamy on 14th Oct, 2009.
did you input the wheel base at all?
if you simply added the ront weight plus the back weight, it wont be the total weight :)
well it will be if it's level, but not if it drops into the rollers.
under 700 is ok for a road car, but that's with sound profing etc.
its not a udl wil
infact, as most of the engine weight is on or even forward of the front wheels, it might even tend to reduce the moment over the rear wheels
Carl
Member #: 95
liverpool-on-sea
hmmm so it may not be tha accurate then. well if its not that accurate whats the point in having on the machine then. will try to get it to a weight bridge
fanx
evolotion
Member #: 83
Glasgow, Scotland
On 14th Oct, 2009 joeybaby83 said:
its not a udl wil
if the car is weighted an axle at a time on a level surface its true weight will be known. simples. doesnt matter where the engine is. *smiley* even if the car dips into a brake roller, i'd put moeny on the error being neglegable.
Denis O'Brien.
let me have a think about this one, im sure i had a trck question the same as this in m1 years ago,
actually, ill eat my own words here, total force down, in equilibrium, equals the sum of total force up
so add the 2 weights together and yes, it will equal (near as dammit) the total force down
apologies for wasting everyones time, wil, i beg your pardon
the upshot....carl, get it on a diet pronto lol
I'd say for a road car it's not to bad mate, mine was 740kgs without me in it recently. (very low on fuel mind you:))
Carl
Member #: 95
liverpool-on-sea
so i dont need to go to the weigh bridge then wahoo.
fink ill go on a diet before the car lol
come to the rr day jim is bringing his scales *happy*
Carl
Member #: 95
liverpool-on-sea
i didnt think me mini would have been done by then so didnt commit and now ive made other commitmants doh
best_stig
Member #: 6449
Brisbane, Australia
Ive heard the starlet motor and gearbox weighs about 20 kilos less than a 1275, but nothing more quantitative than that.
In boost we trust
I was thinking it measured an axle at a time. So if you measured the front axle then the rear, with each end dipped down as you measured it, then it would read heavy. If it measures both axles at the same time, then it wil be as acurate as the scales.
Carl
Member #: 95
liverpool-on-sea
it does measure an axle at a time wil, ill try to get it to a weigh bridge to find out for sure lol
