Home > General Chat > 1 forward gear, 4 reverse
Graeme
Member #: 264
Southampton
While trying to get to sleep the other night I wondered if it would be possible to reverse the firing order, reverse the polarity on the alternator, then.... roll your mini backwards down a hill, but in 1st gear and try to bump start it? Is it possible to run the A series backwards?
Or should I go and see my doc about some sleeping tablets....
Yes, Im getting there.....
www.itsmuckingfagic.com
evolotion
Member #: 83
Glasgow, Scotland
no, think about it (valves, and when they open etc) :)
Denis O'Brien.
Hedgemonkey
Member #: 360
You can do it with a diesel cement mixer. Although the rev limiter won't work.
Yes, the engine did explode.
My mate was once trying to bump-start his mini rolling down a hill, he was just being lazy as it had stalled as he was reversing out on to the road.
Anyway, he accidentally left it in reverse while rolling forwards trying to bump-start it. Amazingly it did actually start, but every time he tried to rev it it stopped.
So it's kind of possible, just no use wasting sleep thinking about it.
Wil
my friend once started a fiesta we had in the field in reverse!?!
When you run a Mini with too high compression, it will run on after the ignition has been cut. It then runs backwards...
jamesfawcett
Member #: 218
Bingley, West Yorkshire
this is mind boggling... because wouldnt the fuel also pump the wrong way on a mechanical engine, and the exhaust suck in and blow out the air filter?!?! god knows cant think about it it hurts!
Andymini
Member #: 438
London
Messerschmitt KR bubblecars had four reverse gears.
It has a two stroke engine and a twin set of points. You just started it in the opposite direction.
Andy
Kean
Member #: 341
aka T2clubby
South Staffs
The fuel pump on a mini wouldnt matter because it works off a lobe on the cam to create a linear motion not a rotary one....
I think you would suck in through the exhaust though.... the valve would open for the exhaust stroke as the piston would be moving down.... hmmm
Vice versa for the inlet
scary....
The oil pressure wouldn't be
up to much though *oh well*
Edited by Kean on 5th Jan, 2005.
pot_dan
Member #: 326
bradford, west yorks
would it not fire at reverse of what it normally would as well. eg 7degrees after TDC?
http://turbominis.co.uk/car/105/
