| Home > General Chat > The Plan | |||||||
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
14th Oct, 2009 at 08:46:20pm
Ok so after studying MANY topics on this sight and getting some input on various parts i decided it may be easyer to post my idea here and get it all reviewed in one go by all.
Edited by Gaball on 14th Oct, 2009. Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
14th Oct, 2009 at 08:48:25pm
Bog standard fast mini turbo engine build TBH, you'll be fine with all of that lot. The only thing I would suggest is using the available manifolds rather than going to the grief of making some.
14th Oct, 2009 at 08:51:13pm
I wont be making them myself, ill use my CAD time to design it (and use it as my project) then get them made up by the college
On 14th Oct, 2009 Tom Fenton said:
Bog standard fast mini turbo engine build TBH, you'll be fine with all of that lot. The only thing I would suggest is using the available manifolds rather than going to the grief of making some. Gaball said:
Carbon but plug? |
14th Oct, 2009 at 08:52:55pm
Ah obviously I know fuck all then, I'll shut up.
14th Oct, 2009 at 08:56:30pm
I wasn't being funny i was just thinking I can do it for my qualification or buy one and the qualification
Carbon but plug? |
14th Oct, 2009 at 09:01:07pm
I've not seen an R5 carb on a mini (but that doesn't mean they won't go). On 11th Feb, 2015 robert said:
14th Oct, 2009 at 09:04:09pm
me neither just something a friend at college suggested trying and for £20 off ebay worth a try haha
On 14th Oct, 2009 apbellamy said:
I've not seen an R5 carb on a mini (but that doesn't mean they won't go). Gaball said:
Carbon but plug? |
14th Oct, 2009 at 09:05:39pm
i always understood it that conrods were less stressed on turbo engines compared to na, but quite a few people have the opposite view.
14th Oct, 2009 at 09:06:47pm
std ones will be fine, Tom uses std ones to over 9K rpm.
14th Oct, 2009 at 09:08:00pm
Standard rods are more than capable. Don't go for big name parts, plenty of home grown mods that are more than capable
On 14th Oct, 2009 Gaball said:
I wasn't being funny i was just thinking I can do it for my qualification or buy one and the qualification but the input was nice maybe you can shine some light on my con rod discusion i have had with my class will the standard ones hold when balanced or will H beams have to be used? On 14th Oct, 2009 Tom Fenton said: Ah obviously I know fuck all then, I'll shut up. On 19th Jan, 2010 wil_h said:
14th Oct, 2009 at 09:13:39pm
saw a thread on here and the TT one was cooling the air well and i was taught (could be wrong) that the efficiency goes down if you start putting big intercoolers on and makes you lose boost.
On 14th Oct, 2009 mini13 said:
std ones will be fine, Tom uses std ones to over 9K rpm. just get some arp rod bolts for peice of mind. (just saw you've aready put that) I'd ad that you don't really need the 1.5:1 rockers, also I'd use the bigest intercooler you can get in and still get air through it, also dont bother with the R5 carb, just use an SU, better suited IMO. Gaball said:
Carbon but plug? |
14th Oct, 2009 at 09:32:57pm
Well thats one of my questions answered
Carbon but plug? |
14th Oct, 2009 at 09:41:38pm
for valves minispares and MED ones are good, probably form the same supplier,
14th Oct, 2009 at 09:56:28pm
i would suspect in the case of bigger cars where people wack a massive intercooler on the front this can be the case (makes sense if you think about it as the very best of intercoolers are only every 80% effiecent) but the confounds of the mini stops you putting something to big on really haha
for valves minispares and MED ones are good, probably form the same supplier, clutch wise, youll probably want to go for a grey pressure plate, and a rally plate, gears wise most people on here usee the minispares clubman kit, seems pretty robust! loosing boost due to too big an intercooler is tosh, whe you raise the boost pressure you'll get heat, this puts the engine nearer to det, so you wan to get rid of as much heat as is practical, as intercoolers are pretty cheap to source IMO it pays to go for somthing oversize incase you want to go furthur boost wise in the future. of course though some intercoolers are better than others for a given size, i've not used one personally bit it could be that the TT ine is particuarly good. Gaball said:
Carbon but plug? |
14th Oct, 2009 at 10:02:21pm
Also anyone with a similar car, what BHP can i be looking at here, i want to set myself a realistic target Gaball said:
Carbon but plug? |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
15th Oct, 2009 at 01:01:49pm
140wp.... Edited by rubicon on 15th Oct, 2009. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
15th Oct, 2009 at 01:04:51pm
Ah obviously I know fuck all then, I'll shut up. tom's had some truth syrum for lunch...
15th Oct, 2009 at 02:04:50pm
Also anyone with a similar car, what BHP can i be looking at here, i want to set myself a realistic target I'd guess around 130 - 150 banana's Team www.sheepspeed.com Racing
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
15th Oct, 2009 at 02:58:19pm
Gayball, where abouts are you in Somerset? |
15th Oct, 2009 at 03:37:18pm
Just up the road from you, i live just outside of South Petherton Gaball said:
Carbon but plug? |
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
15th Oct, 2009 at 07:19:40pm
I have the TT intercooler install, works perfect with 15 psi, the temp after IC around 30 degrees with outside temp of 25 degrees. I have even tried 18 psi, but not for a long time yet..
15th Oct, 2009 at 09:07:16pm
thanks MrTurbo
Carbon but plug? |
16th Oct, 2009 at 04:27:29pm
Good luck! |
