Home > Help Needed / General Tech Chat > Balancing (Yes or No?)
We are just getting ready to put the vans engine back together.
However we are in two minds about whether we should have the rotating assembly balanced. (Crank, Fly, Clutch, Damper)
This is a budget build which we are hoping for about 140+ nana's from when set up. A typical rev limit of about 6k but perhaps stretching to 6.5k for the strip.
The question is do you think it is worth having the balancing done?
Edited by John on 16th Oct, 2009.
Are all the bits from the same engine?
Either way each bit will have been balanced at some point so should be fine for a road engine.
If you had the time and money then yes, but it's not critical for your needs.
EssexSteve
Member #: 7029
Wickford Essex
whats the cost of having it balanced?
imo if the flywheel and crank are from the same engine it shouldnt be far out
Built from 'spares' - preverto flywheel from one engine, rod's and pistons from another, crank from a third, timing gear from a 4th etc etc
Balancing is about £60 iirc.
EssexSteve
Member #: 7029
Wickford Essex
for £60 its got to be worth doing suerly?
I think I'm leaning towards doing it.
We've been trying to work with the mantra 'do it once and do it right' as we've had two many projects getting in the way of our mini builds rescently.
I'd be annoyed if we'd put all the effort in to building it just to have the engine fail due to skimping on a £60 balance...
EssexSteve
Member #: 7029
Wickford Essex
so would i , if it was my engine .
ps still trying to find out if th servo you have will be ok on mine .
steve
tbh whats 60quid? and as you put it like that i would for peace of mind at least
In all honesty I wanted to balance it anyway but wanted an opinion before forking out hard earned. Balancing it is then.
Just got to find time to get the assembly over the balancers.
On 16th Oct, 2009 Brett said:
tbh whats 60quid?
Quite a lot when your budget is £0 *oh well*
tbh whats 60quid?
*surprised* i think you have done well soo far for a 0quid budget
have it ballanced john, as you have a miss match of parts
at that sort of cash i think you would regret it later if you didn't
Yep all the comments on this thread have decided it for us. For the sake of £57.50 including vat we may as well go for it!
where abouts you taking it?
Scruffy
Member #: 328
Seaford Rise, South Australia
After building a variety of engines with help from a mate - he came to rebuild his mum's std 1275 metro and chose to balance it. He reckoned it transformed the car and made it nice to drive!
Can't remember the name, but they are at Glasshoughton
Picked the rotating assembly up last night, they said it was relativly OK for a standard crank. They've taken a fair bit of it, so it should be good now. Also, they've marked it all up so that we can get it back together the same way and keep the balance.
The firm's name is Engine Data Analysis. They where very friendly and helpfull and had a good chat with me. They mainly do Ford and Chevvy V8s, but will do things like balancing for most engines.
they just as you go into Xscape? on the right?
I know there is a race engine building place, they have extractors poking out towards the road.
Yes, kind of opposite MC Donalds.
They where at the Pod at the weekend. We where having a good laugh about that Corsa that chav boy rolled into the barrier *hehe!*
