Home > Help Needed / General Tech Chat > lost all drive at avon park
1380rich
Member #: 4755
warwickshire
was at avon park couple weeks ago and lost all drive, sounded like it'd popped out of gear at first but then realised i had nothing in any gear. happened in first when it gripped off the line
have checked driveshafts and clutch arm and both are fine *oh well* any ideas would be much appreciated
cheers rich
If theres no clonking or rattling maybe the pinion nut came off (like mine did) and the teeth arent meshing.
Otrher than that - diff pin, drop gears, broken clutch plate.....
Paul
1380rich
Member #: 4755
warwickshire
ah sorry i should've mentioned .. when in gear and i try to pull off there is a rattling noise as if somethings spining but not engaging or like you said meshing.
gonna go pull the motor out i think :)
Hope its nothing to major.
Get some pics up of the damage:)
as paul said, could be drop gears or pinion, if there was no noise when it let go, i'd guess pinion nut has come lose.
1380rich
Member #: 4755
warwickshire
It was output shaft :) snapped like a carrot .nice cheap fix. Will get some pics up when i get home to my computer
Cool, never known them break though
Paul
Ben H
Member #: 184
Melton Mowbray, Pie Country
I was just about to suggest output shaft, we broke one last year.
http://www.twin-turbo.co.uk
1380rich
Member #: 4755
warwickshire
Could u suggest a stronger output shaft? It was a tran x one that i just broke
How deep are your pockets?
http://www.force-racing.co.uk/front-suspension/
1380rich
Member #: 4755
warwickshire
If i can get a stronger output shaft thats not a force racing item for the time being until next year then i would like the good stuff lol
1380rich
Member #: 4755
warwickshire
heres the damage *frown*
Ben H
Member #: 184
Nope, can't suggest a better one. We have broken 1 in 4 years with big slicks and driven very hard, so not too dissapointed.
1380rich
Member #: 4755
warwickshire
ahh right, will try another tranx item then, (would really like some nice ti outputs tho) thanks for all the advice
rich
