Home > Technical Chat > 3-wire lambda Q
I've cut the lambda wires on my 205 to get the exhaust off. The sensor itself was err.. stuck. really stuck.
However, I did one stupid thing, that was cutting the two white wires the same length. I've learnt now that it's a good idea to not to...*wink*
However.. Those two white wires, do they need to be connected correctly, or are they "measuring" the same thing?
You know what I mean :)
I think they are just the heater.
pretty sure black is normally sense, and grey & white are heater.
Carl S
Member #: 1761
Stalker
Two white wires are usually the heater wires. According to this site: http://www.lambdasensor.com/main/mcolours1.htm They are not polarised so you can reconnect them either way.
Your 205 has a lambda sensor? That is new to me!
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Yeah, white are just heater and they can be connected up either way. I believe the sensor just acts like a resistor with battery voltage in through one of the heater wires and a residial voltage out. The resistance is what generates the heat. I think 3 wire sensors are earthed through the exhaust so the remaining wire is signal
Edited by GaryOS on 24th Oct, 2009.
On 30th Apr, 2010 Rod S said:
Gary's description is best
evolotion
Member #: 83
Glasgow, Scotland
as above, 2 white wires are heater and not polarity dependant, other wire is the signal wire and grounded through the exhaust :)
Denis O'Brien.
Mine's got both a lambda and a cat, but that's in the bin for now..
It starts without the wires connected though...
GaryOS
Member #: 2810
Dublin, Ireland
All cars start without the lambda sensor as an input. They run open loop until the sensor has completed it's heat up routine
Aha... There so much I don't know about this modern junk...
