| Home > Help Needed / General Tech Chat > oil pressure switch | |||||||
24th Oct, 2009 at 07:35:01pm
im wiring up my mini and im puzzled by the oil pressure switch
297 Posts Member #: 2276 Senior Member sheffield / derby |
24th Oct, 2009 at 10:06:16pm
You could either buy the other type or wire it through a relay? if that makes sense. I've been sorting mine recently as I'm using the switch for the light and the fuel pump wiring, which got me confused for a bit
Edited by 998turbomini25 on 24th Oct, 2009. |
24th Oct, 2009 at 10:25:07pm
You must have 3 metro turbo ones. These work backwards to how you would expect. Get a mini one and all will be well.
24th Oct, 2009 at 11:44:55pm
aha, yes, all the green type off metro 998 engines tom
25th Oct, 2009 at 04:13:16am
Thats exactly why they are the wrong way round |
25th Oct, 2009 at 11:02:06am
ahh, so how does the oil pressure dash light in a metro work? "Turbo's make torque, and torque makes fun"
25th Oct, 2009 at 11:14:06am
I'll be wiring the van's light into the relay for the fuel pump as we're putting a turbo switch onto a n/a loom On 11th Feb, 2015 robert said:
25th Oct, 2009 at 11:26:06am
Most likely the same way the ignition warning light works, ie it has 12V on the other side so lights when it is fed 0V (engine stationary) and goes out when it is fed 12V plus from the alternator.
15th Feb, 2010 at 05:04:03pm
Old thread i know but i cant start a new one, anyway do you think this http://cgi.ebay.co.uk/OIL-PRESSURE-SWITCH-...=item2c5144e513 will enable me to run a fuel pump off the oil pressure and retain a dash light (that works teh right way round) looking at the era diagram http://www.eraturbo.co.uk/technical/technical.htm i cant see how the light comes on when the oil pressure falls? |
15th Feb, 2010 at 05:09:45pm
Ah it has positive feeds from both sides when there is oil pressure, think this means i can get away with only 1 pressure switch and still have a lamp :) |
16th Feb, 2010 at 08:52:36am
Why does the Ebay one have 3 terminals instead of 1?
16th Feb, 2010 at 10:01:33am
Yeah thought it was a bit strange, think i'll use a standard one and wire it as per the diagram, quite a clever way to wire it.. |
16th Feb, 2010 at 07:04:35pm
"Photograph shown is not actual product supplied." |
17th Feb, 2010 at 09:32:06am
Doh! I did think the thread looked the wrong size, good spot ta. |
