Home > General Chat > need some help with spare bits for multi changer.
Basically i have misplaced the multichanger cartridge bit that holds the cds. its std fitment in a xsara coupe. what model is it and anyone know where to get one cheap?
its a 6 disc one, sure its phillips
need some help as ive sold the car and told the gezza id post it off as i was sure i knew where it was *oh well*
cheers
mini6r4
Member #: 426
Maidstone, Kent
i had a feeling the citroen ones were pioneer, if they are, i may have one in the garage you can have. If someone can confirm this is right, ill sort it out for you
Dave
www.mini-roadster.741.com
Roadster conversion kits on the way!
Iain
Its definately a phillips 6 disc, as my Xsara has the same one as yours had.
I will pop outside at dinnertime and get it out and see if there are any code numbers on it.
Out of interest what money did you get for it in the end (PM me if you want?)
Cheers mate, i was hoping you'd see this thread *smiley*
got ?2250 for it so not bad really. what i wanted and its served me well for the last 2 years.
i know that the magazine will turn up when i get another!
give me a hour or so and I'll get back to you.
I paid ?2250 for my VTS coincidentally! But it has done over 100k now.
Anyway, I have been out and had a look. On the actual cartridge there is only one number that is moulded in the plastic, it is 3143 047 5001
On the actual changer the model number is 22RC026/65
Hope that helps matey.
cheers for that, think ive found one on ebay.....
*smiley*
Sorted
just need to win it now!
clubman_dan
Member #: 142
Winchester
snipe it!
will do! *smiley*
