Home > Help Needed / General Tech Chat > OT - Step up transformers
I've managed to pickup a Eberspacher heater for my van, but the heater requires a 24v 10A power supply. My van is only 12v.
Ideally I'd like to avoid running an extra battery just for this heater, so I'm looking to use a step-up transformer.
Obvisouly as I'm a cheapskate, so looking for cheapest option. I'm not scared of getting the soldering iron outas long as they is a diagram for me to follow.
do I have any cheaper options than buying one of these?
http://www.ablemail.co.uk/voltage-converter-Products.htm
No simple solution (well not for moderate/high currents) as it's DC.
Transformers are AC only.
The convertors will use some form of invertor to turn DC to AC and then either a trnsformer/rectifier or, more likely, switched mode - fairly complicated electronics unless mass produced.
Cheers for that rod, I've got my eye on one on ebay
65 quid seems pretty reasonable for the 12 amp one doesn't it?
Yea I suppose it does, but just making sure I was going for the most cost effective option
Turbo Tel
Member #: 588
Delaware, USA
Dont see why you would need an isolated one.. Unless there is a reason to keep the grounds seperate?? Maybe the regular 12A one will do.. its 20 quid cheaper
