| Home > Help Needed / General Tech Chat > Alternative Crank Pulleys. | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
19th Dec, 2004 at 03:07:03pm
I need a crank pulley for a grooved belt complete with damper. Bugger off, I'm getting there. |
20th Dec, 2004 at 01:46:19pm
If you don't want to buy one, make one, or modify a stock one... I'd favour the first option! Single Vee's seem top work for most. Why do you have a dislike?
20th Dec, 2004 at 07:22:57pm
I figure it this way, blower has grooved drive, alternator (RX7) ditto, water pump pulley is easy to make. Leaves me with the crank pulley. Got to have the damper, which might make it interesting on the lathe. Would have to turn a whole load off and then have to fit a fabricated outer to that. (as it isn't big enough to start with). So, I suppose, since my vibrations will have been shifted around a bit, and the rubber is no longer its correct hardness, I could attempt to........no, it's too difficult.
20th Dec, 2004 at 08:56:17pm
What size o/d are you looking at,and its a flat 6 belt ennit
21st Dec, 2004 at 08:52:19am
doesnt the "S" pulley have a bolt on damper? therefore you could make a pulley to suit that? |
21st Dec, 2004 at 01:31:59pm
I was thinking the same - no rubber damper on the 's' engine i recall.... On 17th Nov, 2014 Tom Fenton said:
21st Dec, 2004 at 03:09:16pm
glad to see i remember something right |
21st Dec, 2004 at 05:37:23pm
Yes the "S" damper and pulley come as two seperate parts.
22nd Dec, 2004 at 06:16:04pm
Hmm, interesting. I'll see about that. Bugger off, I'm getting there. |
24th Dec, 2004 at 04:46:22pm
There is a bolt on s damper on ebay :cool:
