| Home > Help Needed / General Tech Chat > Drive shafts too short with Metro hubs & pot joints!? | |||||||
36 Posts Member #: 4743 Member |
19th Nov, 2009 at 01:18:57pm
I've done a bit of reading on this and other forums, and not much mention is made of a problem like what I'm having - I hope someone can help!
19th Nov, 2009 at 01:24:28pm
I have heard bad things about fitting the metro hubs as it throws your suspension geometry miles out. most people just fit the metro flanges to the standard mini hub On 11th Feb, 2015 robert said:
19th Nov, 2009 at 01:25:33pm
First question is, why do you use Metro hubs? On 13th Jul, 2012 Ben H said:
19th Nov, 2009 at 01:33:36pm
the metro hubs throw out all the geometry i believe; your best bet would be to use the standard mini hubs with the metro brakes - i can't recall if you use the metro drive flange or not though |
19th Nov, 2009 at 01:34:34pm
Vegard,
19th Nov, 2009 at 01:36:06pm
king pin inclination is better on the metro hubs though is it not? I think Carl have used metro hubs on his cars? or am I mistaken? |
203 Posts Member #: 1734 Senior Member Lancaster |
19th Nov, 2009 at 02:11:44pm
Whether metro ones are worse or not is going depend on how your overall suspension has been set up including the backspace of your wheels relating to the bottom arm length etc (if adjustable). I'm sure someone with more knowledge than me on this subject can elaborate though. Edited by manifold on 19th Nov, 2009. |
19th Nov, 2009 at 04:15:57pm
ithought denis evolotion was running the mtro hubs and uprights on his to good effect for high speed handling , it reduces the scrub radius and give a longer steering arm to create less sensitive steering at high speed ... i have nevr heard of a problem with shaft length ,perhaps a search on '16v minis.com' would help. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Nov, 2009 at 05:27:47pm
I've used std mini shafts with the metro uprights, they should be fine.
19th Nov, 2009 at 05:54:01pm
On 19th Nov, 2009 robert said:
i i have nevr heard of a problem with shaft length me neither
19th Nov, 2009 at 08:33:22pm
Thanks everyone. I will check the CV joint end; hadn't thought that the shaft could slide too far in. Otherwise, I guess it's a good thing that nobody has heard of the short shaft problem. I will also check the other side... Cheers. Matt |
19th Nov, 2009 at 08:40:41pm
been so logn since i have messed with a-series stuff, but the shafts are different legnths arnet they(just)? could you have 2 short shafts?
Edited by evolotion on 19th Nov, 2009. turbo 16v k-series 11.9@118.9 :)
19th Nov, 2009 at 09:30:13pm
Hmmm but the problem is on the left hand side which is where the short shaft should be fitted....(unless my minds gone blank?)
19th Nov, 2009 at 09:44:35pm
thats true,
21st Nov, 2009 at 09:03:44am
I pulled the thing apart today, and found that the square section clip was in place, and had been holding the drive shaft properly in the CV joint. I also compared the shaft length to two spares I have, and they're all the same, at 373mm. Is this the standard length for LH side pot joint shafts? Could I have an odd CV joint or pot joint?
Edited by mpe on 21st Nov, 2009. |
21st Nov, 2009 at 12:47:08pm
thats Fooking weird!
22nd Nov, 2009 at 03:16:25am
Folks,
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
22nd Nov, 2009 at 09:42:10am
The only time ive had pot joints pull out has been when the engine mount have been buggered. "So wat we gonna do tonight Brain?"
22nd Nov, 2009 at 11:21:12am
Ah,
22nd Nov, 2009 at 04:06:09pm
they sit far out as the firther in you go the less articulation the joint has before binding :) turbo 16v k-series 11.9@118.9 :)
23rd Nov, 2009 at 10:25:23am
On 22nd Nov, 2009 evolotion said:
they sit far out as the firther in you go the less articulation the joint has before binding :) That makes sense. I got to thinking about it, and I reckon the factory designed it with the outermost position in mind. From there, it's got all of 50-60mm inward travel - but probably never needing anywhere near that much plunge... maybe the mini pot design is quite common; similar to other cars which might need more travel.... Matt |
