| Home > Help Needed / General Tech Chat > MPI emissions too high | |||||||
![]() 1014 Posts Member #: 238 Post Whore essex |
22nd Nov, 2009 at 07:27:47pm
my mpi failed the mot on the emissions beig too high, well its the CO that has failed. the fast idle test was 1.213 with a max limit of 0.30 and the second fast idle test was 0.899 again with the limit of 0.30. how can i bring the level down to get it to pass? ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
22nd Nov, 2009 at 07:45:40pm
could it not be a further problem causing the high missions?
Yes i moved to the darkside |
22nd Nov, 2009 at 08:31:17pm
Full engine spec?
857 Posts Member #: 1778 Post Whore Northants |
22nd Nov, 2009 at 08:36:53pm
Do you know what the afr is? Could be that the coolant temp or the air temp sensor has failed |
22nd Nov, 2009 at 09:18:01pm
On 22nd Nov, 2009 sturgeo said:
Do you know what the afr is? Its an MPi Mini, they don't do AFR. lambda on the other hand, they do ![]()
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
23rd Nov, 2009 at 12:27:54am
Typical things :
Edited by turbominivanman on 23rd Nov, 2009. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
23rd Nov, 2009 at 07:23:14pm
its a standard mpi witha cat fitted, the full emissions results are;
23rd Nov, 2009 at 07:53:27pm
Looking at those I'd say its nothing more than a duff lambda sensor.
23rd Nov, 2009 at 08:10:50pm
happy days!, i hope your right tom. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
23rd Nov, 2009 at 09:10:08pm
Comparing those results to the ones below from a perfectly executed test, it would perhaps be due to an excess of unburnt fuel and oxygen either from a slight misfire, or poor valve seal.
24th Nov, 2009 at 08:24:18am
That's a bloody usefull diagram Sprocket On 11th Feb, 2015 robert said:
24th Nov, 2009 at 06:21:19pm
On 24th Nov, 2009 apbellamy said:
That's a bloody usefull diagram Sprocket Its by no means a definative chart, but it groups the different readings together which gives you a better idea. Reading tailpipe emissions after a catalytic converter is a bit of a science experiment, as you have to work out if the cat is working first before you can decide where the problem lies. Have a look at this one for the chemistry
24th Nov, 2009 at 09:02:46pm
just bodging
