| Home > General Chat > Innertubes | |||||||
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
23rd Nov, 2009 at 06:26:20pm
Excuse my wierd question but im lookin to get my newly aquired wheels split and i am a bit miffed as to the having to use innertubes
![]() 484 Posts Member #: 4755 Senior Member warwickshire |
23rd Nov, 2009 at 06:33:39pm
i ran tubes with my force racing wheels and had no problem, ran them at 28 psi.. only place i could find to get them from was mini spares tho :) 2012 Avon class c 2nd place 13.8 @98mph |
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
23rd Nov, 2009 at 09:13:20pm
inner tubes are perfectly legal, i think you might be able to get them from most tyre places as they use them on trailers sometimes, fitttings going to be easier than a non tubeless if thayre 10" due to not having to blast it with an air cannon to seat the sidewalls.
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
23rd Nov, 2009 at 11:39:34pm
I got my innertubes from the local tyre wholesaler about £2 each |
23rd Nov, 2009 at 11:59:12pm
cheers guys it seems a very gray area when your searching for it on the tinterweb as to if theyre legal or not know one seem to know and whether they should be pumped up a bit more |
24th Nov, 2009 at 07:17:44am
Why on earth shouldn't innertubes be legal? On 13th Jul, 2012 Ben H said:
244 Posts Member #: 34 Senior Member |
24th Nov, 2009 at 12:56:12pm
I'm not sure about legal or not, but it is not recommended to fit tubes to tyres below a certain profile.
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
24th Nov, 2009 at 04:30:59pm
On 24th Nov, 2009 Gibbo said:
Also some tyres are not suitable for tubes because of their construction make friction between tyre wall and tube. I had a long phone call with an Yokohama technician - his advise was not to use Yokos with tubes! For that exact reason; the inside of the tyre is to rough for a tube. However, he told me, if I'm desparate to run Yokos with a tube - I shall use much talkum and keep a good eye on the air pressure (under inflated tubes lead to excessive 'rubbing', resp. failure). The reason I need/want to run tubes is that my wheels have a very (very) smal bead on the outside and I'm afraid the tyre might slip off on hard cornering... So I'll risk it. Left; bespoke wheel, right; Exacton (large-ish safety bead w/ a 'hump'): http://img204.imageshack.us/img204/3932/beadsg.jpg Thoughts? [X] nail here for new monitor |
24th Nov, 2009 at 04:36:33pm
You don't HAVE to run tubes with split wheels. You can build them up with silicone between the sections to make them air tight. However then it makes it difficult to get the wheels apart when changing tyres- trying to mount the tyres over the alloy rim means high likelihood of damage. If you can unbolt the rims, then get the tyre fitters to push the tyres off the bead, you can then easily seperate and mount new.
24th Nov, 2009 at 04:45:10pm
I took the Mig MB 10 x 7s and inner tubes to my local tyre man to have the Dunlop wets removed and A032Rs fitted.
24th Nov, 2009 at 05:05:04pm
Would it be that difficult/costly for the wheel manufacturers to have a rubber gasket produced? |
24th Nov, 2009 at 09:04:28pm
This is just what I have found out over the last few weeks...
![]() 359 Posts Member #: 8931 Senior Member Herefordshire |
16th Sep, 2014 at 07:34:03pm
Holy thread revival!!!
16th Sep, 2014 at 08:29:13pm
I fitted tubes to my 165/55/12 A048. The first set had no problems whatsoever. Since then, I've replaced two of them which now deflate over the course of a few hours.
In the 13's at last!.. Just |
16th Sep, 2014 at 09:43:47pm
Got none in my force split rims. No issues yet. |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
17th Sep, 2014 at 12:29:22am
I was once recommended, if fitting inner tubes to radial tyres designed to be used without tubes, assemble with a shit-load of baby powder between the tyre and tube.
David. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
17th Sep, 2014 at 05:30:47pm
I've spoken to my tyre guys about running tubes before, and they will not fit tubes to a Mini wheel - the valve hole is in the wrong place apparently and the inside of the tyres is too rough. Pretty much what has been said before. Metric is for people who can't do fractions. |
