Home > Beginners Tech > Turbo reference sites
TURBO CALCULATOR
Very good site if you want to look at replacing your turbo just buy the calculator and feed your details in
also the cheapest place to buy a turbo in the world (23/12/2004)
http://www.turbocalculator.com/sale-turbos.php
RAY HALL TURBOCHARGING
A lot of good free info and worded for idiots like me
Again you can buy from this site but prices are more average than cheap
http://www.turbofast.com.au/welcome.html
HOW A TURBO WORKS
As title
http://auto.howstuffworks.com/turbo.htm
im sure theres a few more reference sites out there
Edited by wolfie on 22nd Dec, 2004.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Thanks, Wolfie. But see if you can spot the contradiction in this excerpt from howstuffworks:
"A turbocharger helps at high altitudes, where the air is less dense. Normal engines will experience reduced power at high altitudes because for each stroke of the piston, the engine will get a smaller mass of air. A turbocharged engine may also have reduced power, but the reduction will be less dramatic because the thinner air is easier for the turbocharger to pump.
Older cars with carburetors automatically increase the fuel rate to match the increased airflow going into the cylinders."
*happy*
1967 Cooper 's' Turbo build @ www.drjing.com
Wildcat_TurboMini
Member #: 800
Central Kentucky
Great Sites!
:cool:*happy*:cool::cool:
Christian
Edited by Wildcat_TurboMini on 18th Dec, 2005.
Caution- objects in mirror are LOSING!
