| Home > Help Needed / General Tech Chat > Next move. LSD or crank/rod mods? | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
25th Nov, 2009 at 07:02:02pm
Got abit more money to spend on the car. Would it be best to get an LSD or crank and rods lightened/balanced and the other usual mods.
Edited by mayoturbo on 25th Nov, 2009. |
499 Posts Member #: 2257 Senior Member Brighton |
25th Nov, 2009 at 07:31:00pm
Would go with the crank and rods myself...
25th Nov, 2009 at 07:39:09pm
i'd go for the LSD, still on std rods and crank here. Edited by Nick on 25th Nov, 2009. On 20th Oct, 2015 Tom Fenton said:
25th Nov, 2009 at 07:44:21pm
i'd say LSD,
25th Nov, 2009 at 08:08:36pm
I'd say pistons. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Nov, 2009 at 08:10:22pm
You're second in line fella On 25th Nov, 2009 BadgerBaiter said:
But if you go with the LSD, keep me in mind for Xpin ![]() On 11th Feb, 2015 robert said:
25th Nov, 2009 at 08:20:22pm
I'd say diff. You could do either and get away with it but I personally think that extra grip at your current power level, and the ability to keep grip while you up the power abit more on the standard internals (we know they are good or it just watch your revs) is a better way to go than getting the bottom end lightened and balanced and upping the power while loosing grip levels. You won't see full benifits that way round IMO. |
25th Nov, 2009 at 08:24:31pm
On 25th Nov, 2009 BadgerBaiter said: But if you go with the LSD, keep me in mind for Xpin ![]() Bah :p worth a shot
25th Nov, 2009 at 08:26:19pm
Deffo the diff |
25th Nov, 2009 at 08:49:00pm
another vote for diff. |
25th Nov, 2009 at 09:01:45pm
On 25th Nov, 2009 Paul S said:
I'd say pistons. still on std pistons here too, no issues @ 17psi.......yet! On 20th Oct, 2015 Tom Fenton said:
25th Nov, 2009 at 09:40:34pm
My choice would be Quaife ATB, Pre-verto or RTS Clutch much more boost. Then if funds permit go for the crank, rods & then if you have trouble with the std pistons upgrade. If something is worth doing, it's worth doing half of. |
25th Nov, 2009 at 10:49:19pm
LSD! On 13th Jul, 2012 Ben H said:
25th Nov, 2009 at 10:57:34pm
with the torque of a turbo motor i would have to go for an LSD also, get your traction sorted out first and formost,
26th Nov, 2009 at 10:31:50am
How are people finding the ATB? |
26th Nov, 2009 at 10:35:49am
Im quite enjoying mine, tbh I couldnt even notice its there apart from it does leave some impressive 11's up the high street..... |
26th Nov, 2009 at 10:40:41am
Does it keep it in more of a straight line then nic? If something is worth doing, it's worth doing half of. |
26th Nov, 2009 at 10:42:52am
Yes, i seem to recall that once I had tightened up the ball joints it would squat down and go in a straighter line than previous attempts |
26th Nov, 2009 at 10:46:22am
Loose balls can cause problems. If something is worth doing, it's worth doing half of. |
26th Nov, 2009 at 02:15:31pm
deffo! lsd 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Nov, 2009 at 06:34:36pm
LSD it is then, hopefully I can afford to get the bottom end just balanced aswell. Thanks for the replys |
