| Home > Help Needed / General Tech Chat > Name a wire that is yellow and has an in-line fuse | |||||||
28th Nov, 2009 at 03:19:54pm
Hello, still trying to tidy up the few wiring issues I have with the mini and the last one is a fairly thick yellow wire with an inline fuse near the bulkhead. The end has broke off mine and it isn't attatched to anything but I don't know what it should go to and I can't find anything similar in the wiring diagrams that I have. According to the diagrams the only line fused wire in the car is for the interior light but that is purple/orange and mine is yellow. It's a long shot but does anyone happen to know what it's for/ where it goes?
On 7th Nov, 2008 Nic said:
28th Nov, 2009 at 03:34:14pm
according to my diagrams, the only solid yellow wire is for the rear lights.
Yes i moved to the darkside |
28th Nov, 2009 at 03:39:27pm
It's a '79 mini 1000, it's not in with the main loom and goes into or comes out of the back of the intrament binicle near the fuse box. It could have been added by a previous owner I guess, the only things that don't work on the car is the interior light and the hazzards but thats due to something else I think. I am trying to fix it before the carb/manifold goes back on as its easier to fix now, but if I can't fix it then no biggy! On 7th Nov, 2008 Nic said:
28th Nov, 2009 at 03:57:13pm
Flux Capacitor? |
28th Nov, 2009 at 04:20:07pm
Derrick.
28th Nov, 2009 at 06:02:41pm
On 28th Nov, 2009 Nic said:
Flux Capacitor? On 11th Feb, 2015 robert said:
28th Nov, 2009 at 06:06:50pm
perhaps its the one that connects the back loom to the main loom. Its normally red though. Someone may have messed. Take the fuse and see what stops working! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
28th Nov, 2009 at 06:07:23pm
btw are you sure its not white and has gone yellow? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
28th Nov, 2009 at 06:51:54pm
There's an in line fuse to the interior light I think? But from memory that's lilac/white. |
1300 Posts Member #: 829 Post Whore essex |
28th Nov, 2009 at 08:20:41pm
On 28th Nov, 2009 Jay#2 said: is it out of the main loom ?
Hello, still trying to tidy up the few wiring issues I have with the mini and the last one is a fairly thick yellow wire with an inline fuse near the bulkhead. The end has broke off mine and it isn't attatched to anything but I don't know what it should go to and I can't find anything similar in the wiring diagrams that I have. According to the diagrams the only line fused wire in the car is for the interior light but that is purple/orange and mine is yellow. It's a long shot but does anyone happen to know what it's for/ where it goes? Any help appreciated! 1293 Turbo mini
28th Nov, 2009 at 08:48:57pm
It's yellow and it's separate from the main loom, that doesn't match anything in the diagrams. I'm pretty sure it's not the interior light as it's the wrong colour plus it is rather thick with a 30amp fuse.
28th Nov, 2009 at 08:53:40pm
It's not something daft like the radio is it? Added after it came out of the factory? On 11th Feb, 2015 robert said:
28th Nov, 2009 at 08:56:10pm
if you look for it in the trim it may go too a radio or amp 1293 Turbo mini
28th Nov, 2009 at 10:26:46pm
Actually, yous guys might be right, it could be the radio. Hmmm, that would make sense. It used to have one too. I think that solves that mystery, nice work guys!:) On 7th Nov, 2008 Nic said:
28th Nov, 2009 at 10:38:22pm
