Home > Technical Chat > swiftune camshaft ?
turboaseries!!
Member #: 7596
hi im building my turbo engine to turbo phils estimated 130hp spec. but im thinking of getting the swiftune camshaft set which comes with the oil pump, vernier duplex timing setup, cam and followers.
but was wondering if anyone new which one was the best to go for ?
i am not to worried about the car being slightly unpractical in terms of town driving at low rpm, but then again i dont want to have no power at all untill 6000rpm
cheers.
on booosttt
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
SW5 if you only want 130 bananas
On 30th Apr, 2010 Rod S said:
Gary's description is best
the Swift tune SW5 is a good cam and has loads of lift and a short duration i think based on the 1071 S profile i may stand corrected.
here is a few cam timing figures for you to digest
the sw5 has loads of lift but is a tad short on the the exhaust duration in my book, altough a good tractable cam it will produce the good low down mid range and around the 5500 to 6k mark
ideal for 130 bhpish
the MG Metro cam, as fitted to MK2 metro VDP's, RSP Mini coopers, Metro Gta'a and 1275 Metro Sports.
It Has a 1/4" groove machined into the cam after the number one lobe.
Checking height: 0.017" @ lobe
Timing: (Intake): 16/56 (Exhaust): 59/29
Nominal lobe lift: (Intake): 0.263" (Exhaust): 0.263"
Duration (Intake): 252 (Exhaust): 268
Lobe centre angle (Intake): 110 (Exhaust): 105
Lobe separation angle: 107.5
Lift on overlap: 0.054"
NEXT is the Kent 266 a nice all round road cam, these figures are based on kents own specs.
Checking height: 0.016" @ lobe
Timing: (Intake): 24/56 (Exhaust): 61/29
Nominal lobe lift: (Intake): 0.263" (Exhaust): 0.268"
Duration (Intake): 260 (Exhaust): 270
Lobe centre angle (Intake): 106 (Exhaust): 106
Lobe separation angle: 106
Swift tune SW5 road cam,
Timing: (Intake): 15/49 (Exhaust): 52/12
Nominal lobe lift: (Intake): 0.281" (Exhaust): 0.281"
Duration (Intake): 244 (Exhaust): 244
Lobe centre angle (Intake): 107 (Exhaust): 110
Lobe separation angle: 108.5
Lift on overlap: 0.036"
& last is the Avonbar Phase 2
checking hight inlet 0.012" Ex 0.014
Nominal lobe lift: (Intake): 0.360" (Exhaust): 0.400"
Duration (intake) 264 (Exhaust):280
Full lift at 108 deg recomended on here!
But piper says 110 deg on data sheet
The SW5 is based on the 997 Cooper AFAIK. All Ss had the same cam.
