Home > Help Needed / General Tech Chat > inner sill
timboc
Member #: 2043
hi all, going to start replacing my drivers side floor pan and inner sill next week jus wondering if i cut both out do i need to brace it up beforehand?
cheers tim
Edited by timboc on 6th Dec, 2009.
in short No! as long as you leave the outer sill on
timboc
Member #: 2043
bummer, outer sill is off, a-panel is off and front is off,
then i would*happy*
If the door tread section is still there and 100% sound you may be OK but even if it is, personally I would tack a brace just above it across the openning just to be on the safe side. The door tread alone isn't that strong.
I think this is one of those questions that if you have to ask, then you already know the answer *smiley*
I would always aire on the side of caustion and put the bracing in. Better to spend a bit more time now than risk messing your shell up.
Scruffy
Member #: 328
Seaford Rise, South Australia
Is this an outer seal?
Or did you mean an inner SILL
lol
On 5th Sep, 2011 Vegard said:
timboc
Member #: 2043
so whats the best way to brace it up?
weld some box section to the seam where the rubber door seal attaches. About 6" above where you are working so that you have room to get your tools near your work.
Or angle iron like in the picture below the seal......
