Home > How To > connecting supercharger
racemini
Member #: 1359
Belgium
hello, i'm patrick from belgium, can someone tell me how to connect a supercharger (eaton45) on an 1000 cc
all the holes and tubes ??
best regards
patrick:)
Don;t bother, the M45 is not much use on a 998, very inefficient.
If you are insistant then look at the kits that Jonspeed, Vmax and Minispeed sell.
patrick , the hole in the end is the inlet ,and the hole in the side is outlet .have a search on superchargers .
mymedusa
Member #: 7447
use a AMR500 or just a AMR300 from aisin.
racemini
Member #: 1359
Belgium
i know that thanks, its the little hole with a red plastic connection on the side of the pulley?
do you also have to mount a dumpvalve?
thanks voor the answers , i hope you understand my english
best regards
patrick:)
nuukuus
Member #: 6857
Lieto / Finland
Within this forum there are many many discussions on this subject!!!
So go and look images and texts there you find many answers to yours queations!!
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
GTVSaviour
Member #: 8984
Patrick, if you need a hand - where are you in Belgium, I'm in Brussels and can pitch in if you need it.
Can explain the basics etc... - but we'll have to read up on the A-series fitting through these pages.
let me know.
