Home > Help Needed / General Tech Chat > Catalysts?
Mi-Kool
Member #: 7552
Are they required on a 1994 Mini to pass MOT? :)
Any help is greatly appreciated - Michael
yes, '93 onwards require one. Unless you have an engine in the car that was manufactured before '93.
If you can prove the age of the engine then you you only need to pass the emmissions specified for that engine.
Mi-Kool
Member #: 7552
Looks like i just missed out :) Oh well, thank you very much.
-Michael.
The cat dos not have to be present to pass an MOT, but try and pass the cat emissions test without one. Its just not going to happen.
However. up to August 1995 if the tester cannot determine which test should be done, it should be tested on a non cat test. Only after August 1995 you're totaly bolloxed. So, its a matter of finding an MOT tester that understands what Minis are about, and he will then not be doing anything he shouldnt *wink* The bottom line is that it is the MOT testers discretion as to which test is carried out dependant on the year. If he just bangs the reg number into the machine and lets it decide, he is not doing his job correctly *wink* which is what happens most of the time.
Edited by Sprocket on 9th Dec, 2009.
t3gav
Member #: 229
Gavin@minispares.com
kent
Is it carb or SPI?
Good point, but the latter part of my previous comment is usualy what happens and the carb cars get tested on the cat test and it fails nearly all the time
Mi-Kool
Member #: 7552
SPI :)
