Home > Help Needed / General Tech Chat > Diff pins.
Hedgemonkey
Member #: 360
I have taken a load of Final Drives to bits and found some pretty horrific stuff.
They have all worn like it says everywhere. One thing I didn't bank on finding was my relatively new "Performance Pin". It had been used in a tuned but poorly N/A engine and was almost snapped both sides. This isn't a particularly fun engine and I'm wondering about the reliability of non-lsd's in general. One side looked like the planet gear had started the wear first but on the other side, the surface of the pin had "picked up" and shagged basically everything. The gearbox was full of swarf and the thing looked a right old mess. I figure that as I was running 145 tyres, doing quite a lot of spirited driving, the "one wheel spinning" had probably caused the thing to run dry of oil and shag the surface hardening.
So, are cross pin diffs better or do they just halve the wear rate? What have you lot found with your diff pins. Will a 4 pinion diff sort it out?
Got to the point now where the F/D components are being weighed up.
turbo hogster
Member #: 178
stowmaket suffolk
oh yes ive used 4 pin diffs and so has miniwilliams and they are supurb, wear rate is pretty nomanal even in miniwilliams gearbox.
but i can only recomend the minispares item not any others you see with the circular boss these items dont seem to be very good for some reason.
The problem is that people who change their diff pins, don't change the planet wheels. If the pin is fucked, so will the inside of the planet gears be.
This means that if a new pin is udes it will wear out immediately because of the planet gears.
Ask around, if anyone has changed the gears as well. At a guess, noone will have!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
4-pins will wear less by deisgn
but you pay for it *happy*
alex
AlexF
turbo hogster
Member #: 178
stowmaket suffolk
totaly agree always change planets as well.
but for ?165 you will have a bomb proof diff and will take any thing a a series can chuck at it.
those comp diff pins i dont think are that crash hot the planets dont sit on them that well, to much side play.
and i would always fit a 4 pin diff to a turbo even a moderatly boosted one.
Hedgemonkey
Member #: 360
The competition pin was basically shit. I think some competetition pinions would have been a good idea also.
I'm convinced the wear comes from wheelspin on hard cornering.
As hoggy says - stay away from minisport diffs! The basic clue is that the pins should be at 80/100 degrees to each other, not 90 degrees (these are the least preferable type).
If you don't boot it when cornering, your diff should last a long time...
turbo hogster
Member #: 178
stowmaket suffolk
yes td thats the one, but i wasnt going to mention the make but yes it was the minisport one to stay away from.
