Home > Technical Chat > SC drop gears ratio
hydrolastic
Member #: 6668
Just wondering if any body have used the med or swiftune gears Can you change the idler gear to change the ratio's. I would like to be able to change from 3.9 or 3.7 overall depending on the track. Aaron
Racecar spelled backwards is Racecar
If you'd like to change the ratios, buy the ones from Minispares. They've got the most ratios to choose from
Also, it's not the idler that you change, remember this does nothing apart from being a link between the input and primary gear.
Edited by Vegard on 11th Dec, 2009.
mmmm ling soup
OMG a Vegard smelling miskate!
t3gav
Member #: 229
Gavin@minispares.com
kent
Is it worth me doing a post for drop gear part numbers and ratios after the confusion in the other post?
No, not really...
http://calverst.com/articles/Gearbox-Up-ra..._drop_gears.htm
I think it would be more worth while to offer bundles on the website for different engine types and ratios etc.
I know I've previously had to email you to ask which ones I needed....
t3gav
Member #: 229
kent
Some of those numbers on that link are wrong now, even to create a kit for 1:1 drops would mean creating 4 new part numbers which we don't really want to do where possible as it adds to the already increasing list of numbers.
The customer is always right *wink*
do it Gavlar
hydrolastic
Member #: 6668
Yes loads of questions generated with the chart from calver. what is meant by stronger input gear is it compatible with the idler gear or different ratios?
