Home > 998cc > oil pump and stuff
Advantage
Member #: 1450
Near Paris - France
I am about to build an A+ 1100 and am contemplating changing the oil pump.
There is a higher flowing minispares one only applicable to 1275.
http://www.minispares.com/Product.aspx?ty=...0TYPE%20POWER...
To your knowledge, is it just a mater of drilling and taping an extra hole in the block to make it fit ?
What about the required spacer ?
I remember reading about one but maybe was it about switching drives.
Also, I can't seem to find any ARP set for crankshaft renewal, ever heard of that ?
Only an out of stock CON ROD BOLT/NUT KIT 998/1100 ARP RACE
Thanks in advance for your quick response, it is VAT Free week, I don't want to miss that ...
Edited by Advantage on 11th Dec, 2009.
Rusty by nature
No. To make a 1300 pump fit a 998 block, you'll need a spacer between the pump and block.
Get the 998 slot pump. It'll suffice.
If you use a 1275 pump you will need a spacer otherwise the cam won't fit.
To be hinest I wouldn't bother, just buy the best 998 pump available, easily upto the job.
Advantage
Member #: 1450
Near Paris - France
thanks
Rusty by nature
paul (HRE) machined a 1275 turbo pump to fit a 998 for me, for very little money too if i remember rightly
probably overkill, but the only 998 pumps i could find last year were the horrid alloy backed versions
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
So what's considered the best pump for a 998 then, especially for turbo use?
-James
PaulH
Member #: 2340
Dublin Ireland
Yup Joey Is correct I produce a Modified Super flow 9 Gallon a Minute steel backed oil pump which fits 998 blocks all you have to do is drill one hole and tap M6.
it now works out at £38 posted I have 3 on the shelf here if anyone needs one Just PM me and Ill send one out,
regards,
Paul.
On 17th Feb, 2009 Rob H said:
Paul, funnily enough, when i drilled my block, the casting had the extra meat on the block there as if they were originally designed to take a drilling for the large bore pump?
dont know why i brought it up, but made me feel warm and fussy in side, so thought id share
