| Home > For Sale > Belt Drive | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
15th Dec, 2009 at 11:12:26pm
What i believe to be an old mini spares belt drive, i purchased this of a TMF member ages ago and its just bin sitting in my garage, looks in good nic maybe a new belt to be on the safe side they are available from mini spares. Lets say £50 i am not to sure what they are worth?
Edited by Tom Fenton on 16th Dec, 2009. |
15th Dec, 2009 at 11:13:41pm
Dohh! what went wrong there then?
16th Dec, 2009 at 12:13:06am
mac you need a / in the img bit at the end eg [/IMG] Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 161 Posts Member #: 6857 Advanced Member Lieto / Finland |
16th Dec, 2009 at 09:33:15am
There you have.
![]() Edited by nuukuus on 16th Dec, 2009. 1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
16th Dec, 2009 at 09:38:31am
URL's are dead.
16th Dec, 2009 at 09:52:52am
Thanks fellers |
784 Posts Member #: 912 Post Whore North Yorkshire |
16th Dec, 2009 at 12:29:18pm
Not to dampen the deal but:-
I drill holes in everything..! |
16th Dec, 2009 at 02:17:42pm
I wonder what spares they are on about, as long as the oil seals and belt are available what else would you need?
16th Dec, 2009 at 02:42:14pm
My thoughts exactly wil.
16th Dec, 2009 at 04:18:29pm
as a matter of interest ,mac , is there a path for oil to get from the cam bearing drain to the crank , or are they both sealed to the block ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
16th Dec, 2009 at 04:36:06pm
Oil drains behind the oil seals, if you see what I mean. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1425 Posts Member #: 690 Post Whore Norfolk |
16th Dec, 2009 at 08:32:02pm
perfect base for a budget K conversion!
If Carling made Mini engines
16th Dec, 2009 at 09:15:02pm
I may well be being a jackass and usually am, but it seams the gasket, 2 oil seals and a new belt it would come to £16.52 i believe u cant add items to your basket if they are not in-stock?
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
16th Dec, 2009 at 09:36:09pm
id say £50 is about right, i got an ajustable one off ebay a few months ago for 75 and i was the only bidder. i dont understand why they never go for much, guess a lot of ppl dont trust them
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
2nd Feb, 2010 at 07:09:07pm
maccamcvey
If i have more toys than you when i die, I WIN |
9th Feb, 2010 at 09:47:14pm
Sold currently winging its way to Denmark. |
![]() 41 Posts Member #: 1981 Member the Netherlands |
10th Feb, 2010 at 04:26:15pm
I have a roto slide belt drive kit for sale, without the belt that is.
On 8th Aug, 2010 Brett said:
Carl worked my bottom end, cannot fault the workmanship its spot on, a good old chinwag too :) |
