Home > Help Needed / General Tech Chat > 3.2 CW&P, anyone using this ratio?
RED850
Member #: 89
Sydney Australia
Hi Guys,
I am just getting all my bits together to start my gearbox rebuild with the minispares SCCR gear kit
http://www.minispares.com/Product.aspx?ty=...RO%20ST%20RAT...
and wondered if anyone uses the 3.2 diff ratio? (I think it was std metro turbo, is that correct?)
well with this box build i am going std ratio drop gears and going from a 3.44:1 diff to a 3.2:1.
last dyno session on 14psi i got 136hp at the wheels (think that makes it around 180 or so at the crank, correct me if i am wrong)
I really think the 3.2 will help me get away from the line quicker with a little less wheel spin and a nicer cruising speed/revs when in cruise mode.
any thoughts, 3.2:1 too tall or should it be ok.
am running 10" wheels too.
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
Put all your gearbox etc details into this website. it will show you a nice graph of how the car will drive
http://www.guess-works.com/Gearbox/Technical/ratio.htm
you shopuld be able to make an educated guess then
I'm using a 3.1 I dont think its too tall.
nuukuus
Member #: 6857
Lieto / Finland
Same here. I'm using also 3.1
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
RED850
Member #: 89
Sydney Australia
you should be able to make an educated guess then
thanks for that, yep i like those ratios.
seems like 3.2 will be fine.
14.0et @101 mph
