Home > Help Needed / General Tech Chat > How do you blank off carb
miniman03
Member #: 7642
Gillingham, kent
Hi, i want to blank one of my carb unions as i have running problems. it is a metro turbo engine with a hiff44/ SU carb. could anyone tell me how to do this please.
many thanks
Carl
Member #: 95
liverpool-on-sea
i always just use a piece of pipe and a bolt in the end obviously secured with jubilee clips at both ends
you could also strip the carb, remove the brass pipe and have the hole welded up.
or drill and tap the holes.
Edited by Carl on 23rd Dec, 2009.
blob of silicone if your a rough bastard?
I always use a piece of hose and a bolt, so if I decide ot use it in the future its easy to undo.. I suppose you could put a blob of solder on the end, but it if you wish you to use it in the future its a bit more pissing about.
I thought that the hose and a bolt was the only method. Why re-invent the wheel.
