Home > General Chat > rocker cover mods and breathers
jamz
Member #: 2292
Tool
Herne Bay, kent
right first off i need to mod it for roller rockers so as far as im aware i need to grind back the back corners a little?
also what is the best way to have my breathers into a catch tank
do i need to get 2 take offs, one each side on my rocker cover then have crank case going into rocker cover then the other one to my catchtank?
cant beat a good blowout.
probably best to put a pic of your rocker cover up....
jamz
Member #: 2292
Tool
Herne Bay, kent
ook will do but its just one of the basic alloy show off ones.
its only temp as want to get a mini spares or an original metro turbo one
Ben H
Member #: 184
Melton Mowbray, Pie Country
There is no need to put the crank case breather into the rocker, just pipe one from the rocker and one from the crank case into a catch tank. Better still get more than one off the crank case.
http://www.twin-turbo.co.uk
philc
Member #: 1346
bromsgrove
this is my rockerwith breathers
The other thing with these rocker covers is that they have a flat spot to the right of the filler cap.
I have one and was going to drill + tap for a banjo bolt to put a breather pipe on, but I have a better rocker cover now...
998turbomini25
Member #: 2276
sheffield / derby
hi
this is what i did, its just a combination of pipe fittings from B&Q.
Hope this helps
luke
philc
Member #: 1346
bromsgrove
or this
Advantage
Member #: 1450
Near Paris - France
Whow, Luke, that is a neat install !
Rusty by nature
turbominivanman
Member #: 1504
Westbury, Wiltshire
Hi.
Yeah. I think on most aftermarket alloy rocker covers, it's the two rear inner corners that are generally the areas that require relieving with a die grinder or dremel when fitting hi-lift rockers. I had to do this on my early cover before I bought a standard sloping MGT ribbed alloy cover from MiniSpares - that didn't require any mods at all.
I've attached a pic of my breather install on the van which has two K&N engine breathers. This may be of use.
One breather filter is fitted to a 1/2 inch 90 elbow, JB welded into the back of the rocker cover and the other one is fitted on the outlet of the transfer gear case. My pipe from the rocker that goes down past the intercooler pipe, actually T's into the transfer case breather.
I do not have a breather on the timing cover as I have an early belt drive which does away with the breather outlet.
The important thing to remember is that whatever setup you decide, and this includes the simple solution of pipes from your timing cover, rocker and transfer case going into a catch tank with a breather on top, it's important to keep a free and easy exit route for blow-by gases as they escape past the piston rings otherwise the sump gets pressurised and this can lead to blowing oil out past the g/box U seal, timing cover seal, diff seals and clutch oil seal. Also to remember that when the engine cools, it tends to suck fresh air back in, so ideally, it needs to be filtered.
Best of luck with your setup whatever you chose.
Richard.
jamz
Member #: 2292
Tool
Herne Bay, kent
thanks guys. so there is other rocker covers that dont require mods other than the mini spares centre one
