Home > General Chat > Turbo or not??
powcomnaj
Member #: 7860
Hereford
I brought a Mini last week and can't id the engine!!, the engine number is 12HD24 127110
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
i take there is no turbo behind there?
1972-ANGUS
Member #: 3894
http://www.minimania.com/MM/Engine___Ident...ata_UPDATED.htm
This may help!
looks like a standard metro engine:
http://www.guess-works.com/Gearbox/Technic...D24&P2S=&EN_NO=
Is that the full engine no? Guess work's site is looking for a letter after 12HD24
powcomnaj
Member #: 7860
Hereford
Thanks, Guess works site is great!!, no idea why it has a turbo carb!!
johnrg
Member #: 7788
bradford west yorkshire
not
Simon
Member #: 1865
Norwich, Norfolk
as above, thats no turbo carb
How can you be so definate that it's not a turbo carb from that picture?
What I can tell from that picture is that it has a plenum on.
powcomnaj
Member #: 7860
Hereford
It looks the same as this!!
http://turbominis.com/forums/attachments/329028-1.jpg
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Oh cold air induction with a restrictor ring, nice!
On 7th Nov, 2008 Nic said:
naeJ
m
So where did you bring the engine? If you brought it somewhere and cannot find it again, ID-ing can be very difficult.
Fortecphil
Member #: 7641
Jersey, CI
He's got a point..... *hehe!*
metroturbo
Member #: 989
North Yorkshire
12HD24 is a leaded MG Metro engine.
Does it look like the top picture in this thread??
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
In particular the pipe coming from the bit that joins onto the manifold round to the side of the carb
powcomnaj
Member #: 7860
Hereford
Here some picture of it on the car!!
http://s989.photobucket.com/albums/af16/po...aj/Mini%20carb/
Flame Red
Member #: 6267
As far as I can see the only turbo part there is the plenum, it is not a turbo carb. It seems a strange setup to use to get a cold air feed to the carb. I know it has already been said but that's an MG Metro engine.
powcomnaj
Member #: 7860
Hereford
It is very strange set up, over fuel all the time, think i'm going to throw it away and start again!!, are plenum worth anything??
That's an n/a carb. I'll give you a fiver for the plenum
