Home > Wanted > 1275 cylinder head with enlarged cc
johnrg
Member #: 7788
bradford west yorkshire
im after a cylinder head for my 1275 a series, im turbo charging the engine so the chambers need to have been enlarged as i dont want to change the pistons thanks john
Benross or Turbo Phil will be able to enlarge the chambers on a standard head for you if you can't find one
johnrg
Member #: 7788
how do i go about getting it done ?? would i be better off getting new dished pistons ? trying to think of the best way to do it havent made my mind up yet if it is eisier and cheaper to source a head then i will go for that option
On a 1275 engine for a little under 9:1 CR you'll need 10cc dished pistons and 28cc head chambers (or a mathematical equivalent of these two figures). (APPROXIMATELY).
What is the standard dish on 1275 pistons?
johnrg
Member #: 7788
is that what i will need to lower it to for the turbo seems to be a lot im not wanting to go stupid with the boost what sort of psi will that handle
