Home > General Chat > Have i destroyed my diff?
best_stig
Member #: 6449
Brisbane, Australia
Hi everyone,
I was driving home tonight and i could hear a rumbling noise coming from the floor, so i backed off the throttle and let the revs and speed drop. The noise slowed down as speed and revs dropped. At first i thought it was grinding a bearing or something, so i put the clutch in and revved it with no load and the noise stayed the same. So i rev matched to 4th and accelerated and the noise got louder and faster. I babied it home (about 2k's) and have parked it until i decide what to do.
There was a bit of play in the passenger side wheel bearing so i swapped that, but the noise is still there. I couldnt feel any play in the drivers side, but ill be changing that bearing too asap.
The thing that worries me is there is about 5-10 degrees of free slack in the wheel before i can feel the diff engage.
Its got front drums and rubber uni joints.
Are there any other ways i could determine the problem? The engine and gearbox were recond 10 000 ks ago, so im really hoping it isnt broken.
Thanks for your help,
Joe
In boost we trust
What diff is in there? standard or 4 pin?
what sort of power is being put throught it?
best_stig
Member #: 6449
Brisbane, Australia
Sorry, i just edited from a non-turbo mini forum.
Its a stock 998 on a stock diff for a mk1. The whole lot is also 40 years old, so its due a replacement.
In boost we trust
See if the inner joint of the shaft is hitting the exhaust
Paul
i stripdown will reveal all !!
Just to clarify, The noise is still there when revved with the clutch disengaged?
does it do it stood still in neutral with the clutch in and out?
a strip down will be needed either way
best_stig
Member #: 6449
Brisbane, Australia
No it doesnt make the noise when i sit there and rev it.
It also doesnt start until about 30 mph, but its hard to tell as i dont have sound deadening.
In boost we trust
mini_kel
Member #: 7115
essex
As Paul said could be the inner rubber x bush on the driveshaft
