| Home > How To > Std Turbo Fuel Supply Diagram & Connections etc FOR COMMENT | |||||||
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
5th Jan, 2005 at 07:52:57pm
Dug these diagrams out from a rather handy workshop manual, if everyone is okay with these would it be worth deleting the other carb connection topic?? |
6th Jan, 2005 at 02:25:01pm
good stuff dan. perhaps you could put some notes on about which pipes to block off when not using ecu or vent valve to. maybe a note advising the use of an inertia switch? and maybe a good diagram of how to plumb in boost control valve.
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
6th Jan, 2005 at 02:40:17pm
We're not going to get into trouble for copyright stuff or anything are we?
6th Jan, 2005 at 07:48:59pm
fair point on the copyright, i've got no idea on this, do you think 'austin' will mind?
6th Jan, 2005 at 08:45:40pm
These look like copies from 'Austin Rover' rather than Haynes manuals, so copyright is probably pretty safe...
7th Jan, 2005 at 07:40:04am
yep its out of the 'austin workshop' manual
7th Jan, 2005 at 05:39:54pm
I have just read through this bit below, I thought that the idea was to use a larger feed line than return line, thus causing a restriction in the return flow to give a pressure at the fuel reg?
On 06/01/2005 20:45:40 TurboDave said:
These look like copies from 'Austin Rover' rather than Haynes manuals, so copyright is probably pretty safe... That top diagram is fantastic. A few things to add: Pipe at point 1: 10mm diameter hose. Pipe at point 3: 1/4" or 6mm High pressure (EFI spec) hose Pipe at point 7: 5/16 or 8mm hose. Alternativly, 8mm hose can be used for supply and return, but if this is done, a 5mm restrictor needs to be fitted into pipe 3 (ideally at the entry to the regulator - maybe you can edit the picture with an 'x' or something at this point?). Once again, fantastic work!
7th Jan, 2005 at 08:37:59pm
very much the wrong end!
71 Posts Member #: 316 Advanced Member Staffs |
10th Jan, 2005 at 07:56:09pm
i have just asked for help in regards to my mini cutting out "it just won't go..." . i have a 10mm return and feed. What would you suggest?, do you think this could be the problem? |
12th Jan, 2005 at 12:17:30pm
i would suggest restricting the supply.
162 Posts Member #: 228 Advanced Member |
30th Mar, 2005 at 07:48:51pm
so what could be used as a restrictor> could the end of the copper pipe be bent over so its only a 5mm gap at the end? and these measurments im presuming are all i/d
450 Posts Member #: 449 Senior Member Oxford |
30th Mar, 2005 at 08:55:53pm
Copy right is fine if it is being used for education and not to make money normally thats how it works i think |
30th Mar, 2005 at 11:04:02pm
Use anything you want!
339 Posts Member #: 399 Senior Member Austria |
31st Mar, 2005 at 07:38:30am
Is this the right place?
31st Mar, 2005 at 02:49:39pm
yes.
21st Apr, 2005 at 07:56:46am
let me just get this straight then, im using an spi tank, and at the mo im using 10mm microbore pipe whichs is about 7mm i/d for feed and return, with the connections to the tank being in rubber hose with 10mm i/d, looking at this they are way too big, should i go with the smaller microbore pipe i have (8mm , 6mm i/d) for the feed and leave the return as it is?
21st Apr, 2005 at 01:46:27pm
Up to you Ryan.
i just say keep up the good work dan!
