Home > 998cc > Damaged cillinder wall what options
Andrew 998 mini
Member #: 5639
Weert Holland
Hi all
I now have the mini on the road ( we did a 7 eavening weekend two man wrecks to riches rebuild) and now in use I have worked out the current standard 998 engine is from 1974 low compression and a bit of an oil burner even after a cillinder head rebuild.
I had a good high compression 10:1 A+ engine sitting under the bench for a while but when removing the cillinder head for the above engine found two large chips in nr 3 cillender wall B*ll*cks.... I was planing to turbo this engine but i think it is now scrap eny solutions new liner ???? can we confirm it has moved on to the A series engine heaven?
It looks like a wrist pin has poked byond the piston at some stage as the scors ar oposit each other and in line with the wrist pin in the piston the scoors are about the size of a 1 penny coin??
Andrew
Cheers, Andrew
Little car Little power........... For now That is!!!!!
1983 mini down paid, must collect soon and get welding!
You can bore the 998 upto +120 thou, and pistons are available, so depends how deep the scores are, you could try measuring them.
If it's beyond this then it's scrap. But 998 blocks are still cheap in the UK at least £40 usually gets you a decent one.
any pics ?
Andrew 998 mini
Member #: 5639
Weert Holland
Thanks guys I wil try and point the camara in the right direction later on today. an attempt to mesure the depth of the damage.
Thanks
Andrew
Cheers, Andrew
overbore wont be a problem,
hope you get it sorted...
Andrew 998 mini
Member #: 5639
Weert Holland
Hi Guys,
For those interested I have shot some snaps of the damaged bore foto's arnt to good ( new camra still getting to grips with it)
They are on line here:
http://www.mijnalbum.nl/Album=8XXQFKXH
I may have sorced another engine block allready also 998 cc A+ with a holed autobox ( smacked a kurb stone) still atachd to it.
As for the depth of the damage rough mesurment between 2.5 an 4 mm deep*surprised*
Aha Ive figgured out how to get the photos on here now
Cillinder Three with cillinder four at the top of the photo:
Cillinder three with cillinder two (just) at the top of the photo:
the whole engine ( still in its subframe)
Edited by Andrew 998 mini on 10th Jan, 2010.
Cheers, Andrew
tadge44
Member #: 2500
Buckinghamshire
I seem to remember that if you use a block that was on an autobox you will need to modify the oilpump and feeds to suit a manual.Maybe this applies only to 1275,s ?.
Andrew 998 mini
Member #: 5639
Weert Holland
Aha, Thanks for that bit of info, I will have alook at this, I can have the block cheap eny way mabe som useable parts in/on it.
Cheers, Andrew
