Home > Technical Chat > mirage engine specs
danw
Member #: 1885
somewhere
hello
what kind of spec and power are people achieving with the mirage manifold and t2 turbo?
im asking because i want to know if its worth the extra cost on top of the re-build...
thanks
dan
Andrew 998 mini
Member #: 5639
Weert Holland
Ik think I read sowhere yesterday that one of the members got 200 + HP with the mirage manifold so I geus its fine!
Cheers, Andrew
Little car Little power........... For now That is!!!!!
1983 mini down paid, must collect soon and get welding!
yep Nic runs a mirage and has 200+
also Ian ran one and had 180 on 18 psi
although I dont think either of these were with a T2.
It has been shown that the manifold is not detrimental to power.
I wil lsoon have two cars with them on.
danw
Member #: 1885
somewhere
ahh, i had heard that the manifold was a limiting factor, so what kind of spec do we recommend?
just read about the sc 7 port, sounds interesting
standard manifold is fine too, has been used to over 300nana's
danw
Member #: 1885
somewhere
im not sure i want to chop bits out the bulkhead
i've had 154@14psi
with a t2
danw
Member #: 1885
somewhere
is that the pick up engine?
Ahha, that was with a hybrid T2-216.9 bananas
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Thats the main selling point of the mirage setup I guess, if you don't want to cut up your shell then its a mirage or something custom to put the turbo over the clutch housing.
On 7th Nov, 2008 Nic said:
naeJ
m
