| Home > Help Needed / General Tech Chat > What size bore is 1293 or +20 | |||||||
567 Posts Member #: 102 Post Whore Pennsylvania USA |
11th Jan, 2010 at 11:36:15pm
Hi
11th Jan, 2010 at 11:59:43pm
2.8" On 26th Oct, 2004 TurboDave16v said:
12th Jan, 2010 at 12:41:15am
Thanks man |
12th Jan, 2010 at 12:46:26am
Do you NOT have the pistons?
12th Jan, 2010 at 07:35:32am
Always take the pistons down to the machine shop with the block. Isambard Kingdom Brunel said:
12th Jan, 2010 at 08:07:23am
If they are AE or Omegas, bore the block to 71.12mm On 13th Jul, 2012 Ben H said:
12th Jan, 2010 at 09:17:13am
On 12th Jan, 2010 Vegard said:
If they are AE or Omegas, bore the block to 71.12mm or seeing as Colas is in the US, 2.8"
12th Jan, 2010 at 09:29:35am
If they are AE or Omegas, bore the block to 71.12mm or seeing as Colas is in the US, 2.8" ![]() That might work as well
12th Jan, 2010 at 07:47:31pm
I dont have them yet. I'm in the process of getting them. They will be omegas. Thanks guys |
