Home > How To > How to change valve guides
alpa
Member #: 2093
Grenoble, France
I'm sure having seen a discussion here about changing the guides in a kitchen oven. But can not find it again.
So the question is: how to proceed to remove and to insert new guides ?
In this old discussion a person was claiming there was no need to bore the guides after a hot installation, while it's necessary when they are inserted cold (this is what happened to me).
Thanks
Press them out, press them in, ream to size, thats it.
alpa
Member #: 2093
Grenoble, France
To press I need a press, right ? I don't have a press.
It must be possible to do that by heating the head, isn't it ?
Edited by alpa on 12th Jan, 2010.
I just use a hammer.
Make a watsit out of a 1/4" bolt by rounding of the hex.
Put watsit in guide and hit with a drift and a big hammer.
Put new ones in the same way and then ream out. It may be easier if you heat the head first.
alpa
Member #: 2093
Grenoble, France
Thanks, I'll try. I'm short of money, so I need cheap solutions :) .
Advantage
Member #: 1450
Near Paris - France
You're back in France, by the way ?
Rusty by nature
alpa
Member #: 2093
Grenoble, France
Yes I came back this summer. And I'm going to install my stage 2 dev: 295 head, 1bar boost and all the rest to make that work.
You'll need to have the seats recut after this though...
I use a hammer to remove them, but I wouldn't hammer new bronze guides in. The reason is that they get so deformed at the top making it loads more work to ream/file the top of the guide. Also it's much easier to set them to the correct height with a press.
Punching the port-part of a bronze guide is a definite no-no!
Edited by Vegard on 13th Jan, 2010.
