Home > Wanted > t3 turbo needed
bigfeetrob
Member #: 66
Hi guys having just finished installing my turbo into my mini having been promised it didnt smoke ..... Yes youve guessed it loverly light blue smoke out of the exhaust.
I have done the valve stem oil seals and this didnt solve it
So im after a NON smoking T3 turbo to swap directly for mine on the car
Or do i srtip mine off the engine and send it to turbo technics to have the oil seal replaced
Cheers Rob
Email: Bigfeetrob@hotmail.com
Cash waiting
BA_Lordflash
Member #: 26
Cannock
I have one spare as i have decided to do the t2 route however as I have never used it I cannot guarrentee it wil now smoke. Not sure if that is any good to you or not
bigfeetrob
Member #: 66
Thanks lordflash
I will bear this in mind but i would prefer one that has come off a working car and can assure me that it doesnt smoke. prob some one doing a t3 to t2 conversion.
Thanks and i will let you know if i need this
Cheers Rob
BA_Lordflash
Member #: 26
Cannock
well where in the country are you. If you are close enough I am willing to lend it to you then pay me for it if its fine? with two of us it should be quite quick to do etc etc
bigfeetrob
Member #: 66
Im down in the south in between portsmouth and brighton
That would be good if I could trial fit to make sure its ok then pay you for it
Where abouts are you ?
Rob
BA_Lordflash
Member #: 26
Cannock
Unfortunatly i am in staffordshire which is a bit of a problem :( I might be in london in a few weeks so suppose i could bring it with me and we could sort something out
bigfeetrob
Member #: 66
Just to let you know that i have sent mine away to turbo technics as i want to know that another unit wont casue me the sme problems
Thanks for the offer lord flash
They are rebuilding mine for ?200
A bit steep but will be worth it No oil leak and shed loads more boost !!
Cheers Rob
