| Home > General Chat > Subframe reinforcement plates | |||||||
14th Jan, 2010 at 08:46:35pm
Back in the mists of time I'm sure I can remember somewhere offering a kit of plates to weld to your front subframe to help stiffen it, to compensate for the bulkhead box.
14th Jan, 2010 at 09:13:30pm
it was a couple of triagular plates from the towers onto the rear rail and a section of flat bar to sandwich between the rear of the frame and the bulkhead - i think the ideal was to drill and bolt through
14th Jan, 2010 at 09:20:16pm
i have that kit on mine, it was from avonbar
14th Jan, 2010 at 09:41:31pm
I'll make the triangular plates up myself then, I already have a spacer with 3 M10 capheads through the subframe and bulkhead lower down. Cheers chaps.
15th Jan, 2010 at 05:11:32am
are you making progress tom ?
15th Jan, 2010 at 07:15:10am
Slowly as usual !
61 Posts Member #: 7915 Be careful to buy anything from me. You have been warned. westmidlands |
15th Jan, 2010 at 09:55:09am
On 15th Jan, 2010 Tom Fenton said: hi tom on our rallyx minis at back of subframe were it meets bulk head under carb area we weld plate to frame and plate to bulkhead and bolt with through you may need a spacer between that takes load flex out of frame and car steers way better when hitting bumps or long fast bends ! also we used to go through 3/4 sets mounts a season we used 1 set all last year ! and leaves a lot more feel to car . " and one got to says it cant or dont work "" we did a simple cheap test we tied a bit of heafty fishing line from side to side of frame fairly tight after 5 laps it had snapped !! with frame bolted it never broke even when pulled tight ! it has stopped somthing moving ?? john
Slowly as usual ! |
15th Jan, 2010 at 09:59:09am
Any pics of these mods guys? I wouldn't mind a mod like this for my car. If something is worth doing, it's worth doing half of. |
15th Jan, 2010 at 11:08:58pm
On 15th Jan, 2010 minimadmotorman said: hi can get you few pics start of week if you want them ? john
Any pics of these mods guys? I wouldn't mind a mod like this for my car. |
![]() 61 Posts Member #: 7857 Advanced Member NAILSEA, near bristol |
16th Jan, 2010 at 08:54:26am
i had these plates from avonbar years ago, i never knew what they where for or where they went. doh |
111 Posts Member #: 29 Advanced Member Croydon |
16th Jan, 2010 at 09:36:29am
I used this kit when I built mine. Was also from avonbar. From memory there were 4 triagulation pieces and a piece of bar that curved along the underneath of the rear crossbar of the frame.
Too many projects! |
16th Jan, 2010 at 09:55:57am
We did this mod to Ian_w's car. Im sure there are some pics lurking about somewhere! I'll have a dig around https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
31st Mar, 2011 at 10:52:31pm
has anyone dug any photos of this mod? On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
1083 Posts Member #: 8932 Post Whore |
1st Apr, 2011 at 12:16:33am
i'm interested in this too, the only ones i know about are the ones on the tie bar mounts. |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
1st Apr, 2011 at 08:34:19am
minispeed also used to offer this kit... And on the 7th day........... God created turbochargers! |
1st Apr, 2011 at 09:30:27am
The one i know are tie bar, tower to by the break like each side, the one mentioned above and a bar accross the towers just underneeth the bulkhead box Drives
