Home > Technical Chat > Anyone Using Knock Sensor?
Dr. jinG
Member #: 368
Roseville, CA (USA)
Thinking about my engine, I can't think of a knock sensor (pink sensor?) being a part of what I took off. Is there one on the Metro Turbo? If not, is anyone using a knock sensor, and if so, from what (assuming it works well)?
Cheers!
Jon
1967 Cooper 's' Turbo build @ www.drjing.com
touchy!
Metro never had one. If you were lookign at an 'aftermarket' one, you'd need it to be pretty un-sensitive for our three-bearing rattly engines!!!
I'd love to have one however! Have you got a plan, or just testing the water?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
There was a thread on this a while back if you fancy a search!
alex
AlexF
Dr. jinG
Member #: 368
Roseville, CA (USA)
No plan, yet, Dave. Just seeing what's out there, and what's working.
Sorry, Alex. I hadn't seen this topic, so thought it hadn't been discussed. I'll search for it.
Doodmeister
Member #: 149
Alberta, Canada
The Bosch sensors pickup noise from 5hz to 22hz and output is a voltage from 0 to 5vdc depending on the engine noise.
Normal background noise is around the 0.5vdc range and knock is anywhere from 2 to 5vdc.
Summit Racing in the states do a gauge but i don't think it's cheap.
Mike
Member #: 107
Sunny Sussex
just reading about how these work with the MS ECU, i'll do some more research and report back if i find anything useful.
I had a thought about this, some of the wet linered Peugeot engines I have worked on, have a cross-bolted centre main, e.g. bolts from the front and back of the block into the centre main. This also seems to give the location of where they mount the knock sensor. I thought it would be fairly easy to copy this arrangement by drilling a hole through the block to pick up on the main bearing cap, and then fit a knock sensor?
Although I am not 100% sure where the best position for a knock sensor would be on an A series?
Mike
Member #: 107
Sunny Sussex
i'm presuming SPi and MPi dont use knock sensors?
Nick
Member #: 154
Midlands
nope
dan
Member #: 93
just had a ngk/ntk supplier in at work and was looking through their product catalogue and saw this
http://www.ngkntk.co.jp/english/products/e...nsors/p_08.html
Dr. jinG
Member #: 368
Roseville, CA (USA)
Nice! Not sure how it's going to perform, since it's not actually in the chamber, and the threads will probably really affect any kind of reading, but it's a hopeful step in the right direction! I wonder how much that little gem costs...?
Interesting. As the doc says, be good to find out how much £££ they are.....
Dangerous
Member #: 417
http://www.gmcmhphotos.com/gallery/showalb...id=mrerf&aid=59
Dr. jinG
Member #: 368
Roseville, CA (USA)
Looks like it's still using auditory cues, though, if I interpret this correctly, Dangerous. I like the idea of the pressure type better. There are white-papers that show it to be more accurate, and easier to determine if it's a genuine knock and not noise...
http://www.thor-racing.co.uk/Knock_Link-LNK_KNK_LNK.asp
Dr. jinG
Member #: 368
Roseville, CA (USA)
Darn, another one that uses audible cues. Where are the pressure-sensitive setups?
Probably sat behind the $$$$ counter instead of the $$$ counter!
Doodmeister
Member #: 149
Alberta, Canada
Here you go DR but you better get off your wallet as they come in at £1500 each. and your going to need the charge amp also.
http://www.kistler.com/do.productfinder.gb...ram=P1xxx.6052B
evolotion
Member #: 83
Glasgow, Scotland
i know its a bit "tacky" but im about 2 days off megasquirting my motor, and i plan on solidly mounting a piezo mic to the block wiht an amplifier and a pair of headfones and manually listening for knock. ok its not particularly practical for daily driving, but will alow me to tune.. sure i have mentioned this before *tongue*
Denis O'Brien.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Holy smack, that's a lot of smack! I think I'd rather figure out which Saabs have the setup (I believe they did it on some cars) and get one from a breaker... However, it would still require the magic box. -sigh-
evolution, you did mention this before, and I talked to my turbo-guru buddy, and he said that this is probably the best, cheapest method to test for detonation. The human brain is much better at discerning engine knock from normal engine sounds. I'll probably go this route, too. I'm not made of piles of money like TurboDave, so have to look at realistic options, sadly. *wink*
Almost forgot: Congrats on the MS! I'll be going that route, too. Not looking forward to the learning curve, but looking forward to the results! Which board are you using?
Edited by Dr. jinG on 6th Oct, 2005.
There is another TurboDave??? I figure there is, because you can't be talking about the guy waiting for the paycheck after the next one as the next one is already spent...
F'ing mortgage keeps getting in the way of my fun.*frown*
evolotion
Member #: 83
Glasgow, Scotland
o/t apologies *tongue* ..
v3 board and msns-e code, had it on teh car today (made it plug compatible wiht the old ecu with a little extra circuitry) but haveing some bother with the rover flywheel and its stupid 36-4 teeth arangement. highly recomend it though, steep learning curve and much head scratching, but so rewarding :) managed to gat the car to fire once .. its a start *happy*
Denis O'Brien.
