| Home > Help Needed / General Tech Chat > Compression | |||||||
![]() 46 Posts Member #: 5426 Member Belfast |
17th Jan, 2010 at 08:44:23pm
Hi guys, this is a N/A question, but I figured this is a better forum for advice like this, as opposed to TMF... Anyway.
N. Ireland Mini Forum: http://www.mini-chat.co.uk |
17th Jan, 2010 at 08:57:28pm
Inertia or pre engaged? and are you depressing the clutch while turning the engine over?
17th Jan, 2010 at 09:01:06pm
Thanks for the fast reply.
17th Jan, 2010 at 09:11:39pm
Your high compression won't cause you problems with the bottom end. Think how much pressure we get in a boosted car, and they are fine.
http://www.twin-turbo.co.uk
17th Jan, 2010 at 09:43:11pm
I tried a single battery, directly to the starter and engine for earth, and it still had trouble.
17th Jan, 2010 at 09:47:55pm
Is the shsft on the starter covered in clutch dust? Try cleaning and greasing it.
I seriously doubt it! |
17th Jan, 2010 at 09:51:05pm
Yeh, but what were your cranking pressures Paul. I had horrendous problems with the inertia starter and high cranking pressures of 16.5 bar, but I never burnt a starter out. On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2010 at 09:54:16pm
I never had a problem that required me to check my cranking pressure, I wouldnt know Colin I seriously doubt it! |
17th Jan, 2010 at 10:00:10pm
Thanks guy!
17th Jan, 2010 at 10:35:53pm
if connecting 2 batteries in parallel is the only sure way of making it turn over and fire is that not pointing at a weak battery? maybe the cold crank rating of the battery simply isnt high enough for the high compression engine
Yes i moved to the darkside |
17th Jan, 2010 at 10:41:40pm
I think the starter problem is only the begining of other problems unless Shell V power and an optimised ignition advance curve are used and properly set up on the rollers with Det cans On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2010 at 11:56:23pm
The batteries I used were both fully charged.
18th Jan, 2010 at 12:11:21am
18th Jan, 2010 at 12:28:57am
Ah I see, well im running her on premium unleaded from at the minute.
18th Jan, 2010 at 11:01:51am
re attach New earths to the engine from the body work at least 2 and ........ make 2 good ones from the battry to the bodywork
18th Jan, 2010 at 11:14:41am
I think you have a wiring fault. There must be a fault for the voltage to drop that much when cranking. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jan, 2010 at 11:17:42am
Well, the front wiring loom in the car is piece together from a couple of different minis.
18th Jan, 2010 at 11:29:29am
I would start by measuring the resistance of the feed wire and ensuring you have a decent connection to the battery and starter. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jan, 2010 at 11:34:37am
Here's an idea:
18th Jan, 2010 at 01:08:44pm
A SW5 with 10.5:1 compression might be much harder to turn over than a 296 on a 11.5:1.
18th Jan, 2010 at 01:14:58pm
So is something terribly wrong ?
23rd Jan, 2010 at 06:48:08pm
An update for those who could GAF.
23rd Jan, 2010 at 08:50:10pm
I GAF Dez
23rd Jan, 2010 at 08:53:38pm
Cool,
23rd Jan, 2010 at 09:51:27pm
Lol Paul!
