Home > Technical Chat > Seperate oil for diff
Just for the fun of it, and out of boredom, Ive looked at seperating the oil for the gearbox and diff so that proper LSD oil can be used and modifying the casing couldnt be easier.
Its just the bearing in the centre web needs to be sealed to prevent the oils mixing. Does anyone know if its possible to get a sealed bearing at all?
Paul
why bother, have you just found out that diff oil is lighter than 50 weight engine oil,
carl
As above, just out of boredom Im wondering if it can be done
Advantage
Member #: 1450
Near Paris - France
What about separating the engine from the box with a sealed baffle plate ?
Then converting the engine to dry sump (obviously given the volume remaining ...).
So you can use proper oil in the gearbox and performance oil in the engine.
Doable or what do you think ?
(and why not convert the name of the posts to "crazy projects" ?)
Rusty by nature
I can think of many more ways to satisfy boredom than try this *hehe!*
Pervert!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I recently thought about having a seperate pump and filter for turbo feed. At least if the engine goes bang it won't take the turbo out with it.
On 19th Jan, 2010 wil_h said:
Why would it take the turbo? the pump yes, but the oil has to pass through the brick gaurd, then the filter before it gets to the turbo
evolotion
Member #: 83
Glasgow, Scotland
seal the diff unit itself as the bike engine minis do :) in its own we case, and the whole thing can sit in the oil without issue..
Edited by evolotion on 20th Jan, 2010.
Denis O'Brien.
maccamcvey
Member #: 6673
Worral Sheffield
Is that a renthal chain ring? I have one on my jump bike :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Was thinking more low oil pressure
Advantage
Member #: 1450
Near Paris - France
Not bored anymore Paul ?
The dry sump sounds good to me, just have to machine the gearbox to deal with added thickness of the baffle plate
(I'm bored too ! *happy* *happy* )
Rusty by nature
