| Home > Help Needed / General Tech Chat > A-Series 998 oil pump | |||||||
20th Jan, 2010 at 04:36:07pm
Are they all pin drive? I run a supercharger and I don't care the TB is on the wrong side.
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
20th Jan, 2010 at 07:31:41pm
I hope not !
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
20th Jan, 2010 at 07:58:29pm
To make it clear I'm only talking about pre-A-Plus I run a supercharger and I don't care the TB is on the wrong side.
20th Jan, 2010 at 08:39:49pm
Are you wanting to change the pump or the cam?
20th Jan, 2010 at 10:40:22pm
I was trying to get away without changing the pump however I think the cam will dictate the pump... I run a supercharger and I don't care the TB is on the wrong side.
21st Jan, 2010 at 07:57:14am
How old is the pump? I would call them a service item if the cam is coming out... On 11th Feb, 2015 robert said:
21st Jan, 2010 at 08:05:57am
On a 1275 I'd agree, but on a 998 with the tappet chest covers, its feasible to swap the cam "properly" e.g. with followers, without stripping the engine.
21st Jan, 2010 at 09:36:54am
yep the pump is still showing very good oil pressure. I doubt I will get a cam that I want with a pin drive.
21st Jan, 2010 at 09:40:04am
Could you not have yours reground Graham? If something is worth doing, it's worth doing half of. |
21st Jan, 2010 at 09:43:36am
Buy a pin drive from someone, have it reground! On 13th Jul, 2012 Ben H said:
21st Jan, 2010 at 09:59:40am
On 21st Jan, 2010 gr4h4m said:
yep the pump is still showing very good oil pressure. I doubt I will get a cam that I want with a pin drive. That doesn't mean that there isn't wear inside the pump. The van's engine ran good oil preasure (not that we had a gauge) but the inside of the pump was badly worn and scored. A slot drive 998 oil pump is only £15... On 11th Feb, 2015 robert said:
21st Jan, 2010 at 07:20:57pm
On 21st Jan, 2010 Vegard said:
Buy a pin drive from someone, have it reground! I run a supercharger and I don't care the TB is on the wrong side.
22nd Jan, 2010 at 08:03:04am
Why not mail Stuart Gurr and ask if he has/could do you one to your needs On 11th Feb, 2015 robert said:
22nd Jan, 2010 at 08:49:47am
Can you do this with a std cam? I stupidly thought that you needed bigger lobes? but I'm new to all this cam stuff... Most aftermarket performance cams are reground from standard ones, they just reduce the base circle diameter to "gain" the extra on the lobe to change its shape. Only if the word "billet" or similar appears in the title (and it's 5 times the price) will it have been ground from a new casting and have the correct base circle diameter. Edited by Rod S on 22nd Jan, 2010. Schrödinger's cat - so which one am I ??? |
22nd Jan, 2010 at 10:40:00am
oh I see Thanks Rod S.. I was being a bit simple with my understanding.. I run a supercharger and I don't care the TB is on the wrong side.
784 Posts Member #: 912 Post Whore North Yorkshire |
22nd Jan, 2010 at 12:31:40pm
Not to steal you thread.
I drill holes in everything..! |
