Home > General Chat > compression ratio
johnrg
Member #: 7788
bradford west yorkshire
how is c.r calculated my c.r on my car is 9.4-1 so if i had my chambers enlarged to 27cc what does that make my new c.r and would it be lowerd enough to add a turbo to it anyony ????
johnrg
Member #: 7788
anyone???
No answer after 43 seconds, come-on give us a chance.
Google CR there's lots of on-line calculators.
Presuming you have the standard chambers now (21.4cc) and as 9.4: will be fine for 10 or 12psi then a rough finger in the air would suggest that the 27cc chambers would allow 15+psi.
it is the ratio of the combustion space to the swept area plus combustion space of one cylinder,
so... if you have a 1000cc 4 cyl engine one cylinder will be 250cc, if that cylinder has 25cc space at TDC then the compression ratio will be 11 to 1
to calculate it take the swept area (250cc) ad it to the combustion space (25cc) and divide it by the combustion space (25cc) 250+25 (=275)/25= 11.... easy(second time round....)!
or stuff some figures in this *wink*
http://www.afracing.com/CR.xls
edited to be right....
Edited by Joe C on 20th Jan, 2010.
not quite, its swept volume plus unswept volume divided by unswept volume
bollocks....
hurry's to check own spreadsheet...
johnrg
Member #: 7788
wil h i corrected my spelling after 43 seconds fron anyony to anyone lol i got all the time in the world m8
