Home > General Chat > snap off bosses
Im sure there was a link to some reasonably priced snap off bosses on here (around £30 mark) but I can't seem to find it? Anyone got a link?
Matt
jamz
Member #: 2292
Tool
Herne Bay, kent
id be so intrested too if that is right lol. even at 40-50 quid. thats cheap
cant beat a good blowout.
There are plenty on ebay, but the one that was linked on here I really liked the look of, and it didn't bring the steering wheel too much closer.
Fortecphil
Member #: 7641
Jersey, CI
I got mine from Mcgill Motorsports, good quality also - this one here:
http://cgi.ebay.co.uk/Quick-Release-Steeri...=item25578249c0
There is cheaper on ebay also....
Hope this helps:)
jamz
Member #: 2292
Tool
Herne Bay, kent
so it just slips over the excisting splines and welded it on? then hay ho got a snapp of boss? that actually includes the boss to
Fortecphil
Member #: 7641
Jersey, CI
Yep, pretty much about it - Everything included to fix. Press the button & off she pops...!
weld on ayee... that could be a fix for my fooked threads on my column :)
philc
Member #: 1346
bromsgrove
i don't think you will find one cheaper new
Fortecphil
Member #: 7641
Jersey, CI
The only thing i found was once welded on the indicator/wiper stalk bracket is too small to fit over the adaptor - my steering column is slightly modified so i wasn't too fussed, but you may want to know... oh and you won't be able to take the shaft out from the column either....
cheers for the info
And once you weld it on you'll never be able to change the bushes in the column.
Fortecphil
Member #: 7641
Jersey, CI
In a standard application, short of using a grinder to remove said adaptor, you are correct...
