Home > Beginners Tech > Rolling body on to its side
longy
Member #: 2727
Bicester
Hey guys,
just want to hear everyones views on rolling the body shell on to its side. ive got a load of work to do on the under side, dont fancy laying on my back for weeks.
My concerns are damaging the panels or distorting the shell.
1972 998 TURBO SLEEPER
When I had my jet black I drained the fluids and took the mirror off and just tipped it on its side on a mattress. Didn't seem to suffer any ill effects.
Also my cooper has spent plenty time on its side as a bare sell with just a bit of carpet and a lump of wood to support it.
Mines been on and off both sides many times during the repairs to the shell (piccies in my build thread).
No subframes so in it's lightest possible form but no damage whatsoever.
I used an old quilt but added old pillows where the A, B and C pillars would roll so no load went on the side panel anyway.
Only problem I had was setting fire to the quilt while welding...
advantage998
Member #: 1840
Kings Lynn, Norfolk
As above really with the shell mainly resting on the sill seam and roof seam.
longy
Member #: 2727
Bicester
Cheers guys
I used to support the car off the gutter with a bit of timber to stop the fell weight sitting on the panels - effectively the shell was resting on the sill seam and gutter.
Only issue i had was that lining up or ensuring doors gaps are good is a bit more of a pain.
just make sue you protect the matress as they can burn!
go down the tip and find a piss stained mattress, viola!
graemec
Member #: 1424
Carnforth, Lancs
That'll smell gorgeous once on fire!!
I've previously used old tyres under the sill seam and gutter seam. Don't ignite quite as easily and give you a bit of room to sweep up under the car if you're doing a messy job.
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
This is all good stuff, whats the recommended procedure then?
The tipping moment?
longy
Member #: 2727
Bicester
Thanks for your help guys,
Angus it seems that you just have to grip it and rip it. dont think theres anything scientific about it.
I've happily turned bare shells on there sides before, using strategically place car tyres to protect them.
EDIT: Hopefully corrected the grammar.
Edited by Rob H on 29th Jan, 2010.
longy
Member #: 2727
Bicester
just thinking out loud, ive got the front end chopped off, has anyone considered turning the sheel on its nose and supporting it on the bulkhead?
Scruffy
Member #: 328
Seaford Rise, South Australia
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=338258
Why not buy this off of me local to you also! Shameless plug!:)
On 5th Sep, 2011 Vegard said:
longy
Member #: 2727
Bicester
Scruffy love the plug, very cool, but funds are tight and needed else where so i think its going to have to be old tyres. love the frame though
Haha I did mention that to Longy as an option!
longy
Member #: 2727
Bicester
would it fit in a standard sized single garage?
Scruffy
Member #: 328
I would say yes it is only marginally wider than a Mini- actually looking at the pictures it is the same if not narrower. I can measure it for you if you want but only if serious as have terminal Man cough from no1 brat at present - feel like I have been smoking 60 fags today!
longy
Member #: 2727
Bicester
dont worry scruffy thanks though
